97 jeep gc factory alarm disable?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=96436
Printed Date: May 04, 2026 at 1:36 PM
Topic: 97 jeep gc factory alarm disable?
Posted By: 929freak
Subject: 97 jeep gc factory alarm disable?
Date Posted: August 16, 2007 at 12:00 AM
hello everyone!! I did search on here and found out that if I ground the violet / YELLOW wire in the dfriver door boot it will keep the factory alarm in the disarm state...here is the prob,I had a alarm, keyless,remotestart installed,the factory alarm .blows when I arm(don't like that) and when I remote start it sets off the factory alarm if I dont disarm first(too much to remember,ha ha) I did  ground the violet/yel wire, great no more beep on arm and no alarm when I remote start,only prob is when I arm(lock the doors w/ transmitter) the interior lights stay on!!! (arghhhhh)does anyone have an easier solution?? any hel pis GREATLY appreciated.......
Posted By: JWorm
Date Posted: August 16, 2007 at 8:40 AM
Hook the violet / YELLOW to the disarm wire of your remote start instead of permanately grounding it.
Posted By: 929freak
Date Posted: August 16, 2007 at 3:24 PM
yes that would stop the alarm from going off during remote start,but the factory horn would still honk on arm/lock.....if I'm not mistaken the disarm wire only sends a signal during remote start and disarm,not arm...?? I could be wrong
Posted By: JWorm
Date Posted: August 16, 2007 at 11:03 PM
I believe you can turn off the horn honking by using the controls in the overhead console. I might be wrong....it has been a while.
Posted By: 929freak
Date Posted: August 17, 2007 at 9:24 PM
thanks for tryin jworm...no overhead console,factory moonroof. only a trip meter and mpg guess-o-meter
