98 s10 shaved door handle wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=96551
Printed Date: May 02, 2026 at 3:07 PM
Topic: 98 s10 shaved door handle wiring
Posted By: atomicspark
Subject: 98 s10 shaved door handle wiring
Date Posted: August 21, 2007 at 4:15 PM
I was wondering if i could get some help on this wiring problem that i have. I have a 98 S10 and i purchased a shaved handle kit from AVS. I installed the units and they all pop and work fine... the only problem is how do i set it up to open the drivers door on the first push of the unlock button on my alarm. My alarm is a Clifford Matrix 50.5X. Any help with this would be greatly appriciated! Thanks
Posted By: caralarmtec
Date Posted: August 22, 2007 at 12:08 PM
You will need to wire up 2 relays to the unlock output of the alarm system.
17 Year Veteran Tech
Date Posted: August 22, 2007 at 12:29 PM
how would i set up the relays?
Date Posted: August 22, 2007 at 12:37 PM
Give me your email and I'll send you a relay diagram in PDF format.
Date Posted: August 22, 2007 at 2:32 PM
jeff@marshalmoody.com
thanks i greatly appriciate it
Date Posted: August 22, 2007 at 2:56 PM
No prob! sent!
