02 accord 4 dr window roll up/down
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=96689
Printed Date: April 30, 2026 at 10:37 AM
Topic: 02 accord 4 dr window roll up/down
Posted By: proatthagame
Subject: 02 accord 4 dr window roll up/down
Date Posted: August 27, 2007 at 5:07 PM
I have the compustar cm3000. I am currently studying the MECP basic installers guide and from what ive read about relays and diodes, can i hook up my alarm so when i use the aux1(-) or aux2(-) my remote the windows will go up and down, but i also would like them to roll up when i lock the doors. Can i do this without purchasing the window roll up module,but by just using the appropriate electrical components?
Yours Truly
Posted By: KarTuneMan
Date Posted: August 27, 2007 at 5:48 PM
The appropriate electrical componants are the window modules...posted_image
Date Posted: August 27, 2007 at 7:03 PM
Thats not the answer i was looking for but thanks.....
Yours Truly
Posted By: captainzab
Date Posted: August 27, 2007 at 7:10 PM
it wouldnt be safe or even smart at all to use relays and diodes and stuff you would need 2 relays per door (one going up and one going down) plus, you would have to hold it to make sure it stops at the right position, if you hold it too long it could mess up the motor (window module watches out for this)
anyways, u can use an aux to roll window down, then your ground when armed wire will roll the windows up when you press lock (no need to use aux 2 roll window up) assuming your using dei 530T (i havent used any other type)
basically, a window module is the ONLY way to do it
Note: You Always Dont Get What You Pay For.
Date Posted: August 27, 2007 at 8:39 PM
Uhmmmm..... never mind.
Date Posted: August 27, 2007 at 10:49 PM
Thank You Sir.
Yours Truly
