1995 chevy van door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=96710
Printed Date: April 11, 2026 at 2:12 AM
Topic: 1995 chevy van door locks
Posted By: liverlips
Subject: 1995 chevy van door locks
Date Posted: August 28, 2007 at 2:10 PM
Hello,
My dilemma is: I have a 1995 Chevy Gladiator G-20 conversion van I have installed an alarm system and have everything figured out, installed, and working accept the door pin switch that sets the alarm off and the door lock-unlock wire combo.
The door pin switch is a negative switch I believe which the drivers door pin switch has 2 wires connected to it and all the other ones (passenger, side, and rear) only have one wire connected to them.
The factory door switches have a 3 wire connection. 1st constant hot(orange and black), 2nd one negative (solid black), and 3rd negative (blue) wire.
Looking at the manual from the alarm is where I am getting confused. It’s showing at the top of the box unit a small jack that has three wires saying blue-unlock, red-12v + out, and green-lock. Then looking at the side of the alarm control box there are green….(-) door trigger, blue….(-) trigger, and violet….(+) positive door trigger wires. I do not understand which goes with which. Have tried several combos and nothing works. From reading it seems I might need a relay. I also have read through the “Hanes” book on the van, but it is not any help.
Any suggestions would be greatly appreciated…..
Thanks,
Tom H.
(liverlips) Tucson, AZ
Posted By: vitrox
Date Posted: August 28, 2007 at 4:45 PM
as old as that van is, it most likely has reverse polarity locks. you will need a diagram to wire those up.  and you only use one door pin wire from the brain. Likely it will be the green (-) input wire.  Just check with a probe on the door pin to see which wire changes polarity from floating to negative when the door is opened.
Posted By: mikvot
Date Posted: August 28, 2007 at 6:52 PM
Power Lock
Power Unlock
Door Trigger
Of course this info needs to be tested with a dmm!
CHEVROLET, VAN, 1995, Door Trigger
Also found behind instrument cluster.
Your door locks on the van should be (+) which means you will need two relays to convert the (-) door locks pulses of the alarm to a positive.
Your door trigger will be (-) so the  green(-) door trigger of the alarm should be hooked up to this. Violet would only be used if you had a (+) door trigger so you don't need to worry about that one.
The blue(-) trigger on the alarm would be used for something like a hood pin.
Date Posted: August 30, 2007 at 5:32 AM
Hey Guy,
Thanks for taking the time to answer. On the door locks, I have found that the orange wire being (constant) positive , if I take a jumper wire from the orange to the blue- it locks; then when I take the jumper wire from the orange to the black it - unlocks. Does this stil mean it is a negative door lock system?
Posted By: JWorm
Date Posted: August 30, 2007 at 9:58 AM
As stated above by mikvot your van has 3-wire positive doorlocks and you will need to add relays: Relay Setup
Instead of relays, you could use: Polarity Inverter    Relays will be easier to find...you can get them at Radio Shack. You could stop by an alarm shop and ask them if they have a door lock polarity inverter. It converts a (-) pulse to a (+) pulse.
