door lock wireing for 91 ford escort
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=9701
Printed Date: April 04, 2026 at 3:58 PM
Topic: door lock wireing for 91 ford escort
Posted By: shortie
Subject: door lock wireing for 91 ford escort
Date Posted: February 18, 2003 at 4:07 PM
my escort has a two wire acuators. There is no lock switch it is activated by the manual loock switch up on top of the door panel by the glass need help.
Posted By: fire200799
Date Posted: February 18, 2003 at 6:32 PM
what are you wanting to know or do?
Posted By: shortie
Date Posted: February 18, 2003 at 7:28 PM
how to wire them to a viper 300 alarm to activate the keyless entery
Posted By: AlarmTech
Date Posted: February 20, 2003 at 2:43 AM
I'm pretty sure your Escort is a semi central locking system (same as my 90 Protege) (read as: cheap bastards can't spring for one more actuator:))you'll need to add an actuator to the drivers door to get keyless entry. There is a switch in the drivers door that activates the relays to the other door(s). but there is no actual actuator in the drivers door, just that switch. Which is why one is needed for keyless entry. You will still need to add relays to control the newly added actuator.
