total window closure
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=97090
Printed Date: April 30, 2026 at 4:04 AM
Topic: total window closure
Posted By: eireal
Subject: total window closure
Date Posted: September 12, 2007 at 5:12 PM
Hi Guys
Wondering if someone could point me in the right direction.
If a car has an aftermarket window roll up module (2door/front windows only) and you want to add on the sunroof as part of the closure,is a seperate module needed or can the sunroof be "piggybacked" so to speak into the original aftermarket module?
Posted By: kola7126
Date Posted: September 13, 2007 at 4:02 PM
What is model of you`re car?
Posted By: KPierson
Date Posted: September 13, 2007 at 9:21 PM
You will need a seperate module.  The module should provide current monitoring for a 'anti pinch' situation.  If you add more current to the circuit it most likely will kill this feature.
Kevin Pierson
Posted By: JWorm
Date Posted: September 14, 2007 at 8:37 AM
You need a seperate module. Look for a DEI 529T. If you "piggybacked" the sunroof then the sunroof would open and close whenevr you open and close the window it is piggybacked with.
