remote starter problem, 95 cutlass supreme
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=97164
Printed Date: April 29, 2026 at 12:56 AM
Topic: remote starter problem, 95 cutlass supreme
Posted By: silverfoxx129
Subject: remote starter problem, 95 cutlass supreme
Date Posted: September 16, 2007 at 11:19 AM
Hi, I have a 1995 cutlass supreme and I installed a remote starter/alarm in it, now when I try to use the remote start I hear the fuel pump start, the lights on the dash light up and then it unlocks the doors and then it stops, I have installed a bypass kit for the vats. The car has remote door openers installed from the factory that I think is the fault, 1 more thing, I unhooked the door lock/unlock wires on the unit I installed and it still unlocks the doors when I use the remote start. thanks in advance, Brad
Posted By: chadwa2003
Date Posted: September 16, 2007 at 11:27 AM
Did you hook up your second ignition what kind of starter is it
Date Posted: September 16, 2007 at 11:30 AM
thank you for the reply, the unit is an HUATAI HT600, there is no 2nd ignition wire. thanks, Brad
Date Posted: September 16, 2007 at 11:51 AM
No No not on the unit in the car there are 2 ignitions one pink and it says purple but it could aslo be pink/white or white
Date Posted: September 16, 2007 at 12:05 PM
I hooked the ignition wire to the pick wire(1st ignition) there was no mention of the 2nd ignition wire in the instructions and I also asked the person that I bought it from how to wire it, would that unlock the doors and shut down the remote start? thanks, Brad
Date Posted: September 16, 2007 at 5:10 PM
Not necessarily but you will definately need that try to remote start the car with the key in the ignition if it starts than there is something wrong with your bypass if not then there is something wrong your install
Date Posted: September 16, 2007 at 5:17 PM
lol. been there done that, that was the first thing that I did. I am hopeing that someone can tell me how to disconnect the factory lock/unlock system that is in the car to see if that is the problem. thanks, Brad
Date Posted: September 16, 2007 at 5:27 PM
Your locks should have nothing to do with it does it start with the key in the ignition
Date Posted: September 16, 2007 at 5:33 PM
the problem is that when I try to use the remote start it turns on the fuel pump sends voltage to the starter then unlocks the doors and it never engages the starter. thanks, Brad
Date Posted: September 16, 2007 at 5:39 PM
First of all hook up the second ignition and remote start the car with the key in the ignition cylinder. Does it start
Date Posted: September 16, 2007 at 5:42 PM
Hi, are you saying to unhook the ignition wire that it's hooked to and hook it to the 2nd ignition wire? thanks, Brad
Date Posted: September 16, 2007 at 6:02 PM
No you need both igns hooked up
Posted By: init
Date Posted: September 16, 2007 at 6:08 PM
If your remote starter doesn't have a second ignition output, but your car has 2 ignition outputs, you'll need to send power to both of the car's wires using relays.
Date Posted: September 16, 2007 at 6:40 PM
Hi, I hooked up the 2nd ignition wire and it still does the same thing with the key in the ignition and not in, the part that I don't understand still is the doors unlocking when I try to start it with the remote. thanks, Brad
Date Posted: September 16, 2007 at 8:48 PM
It's probably set up to do unlock before lock after start some systems use this as a factory alarm disarm function
Date Posted: September 17, 2007 at 5:32 AM
Hi, the problem is that even if I unhook the door lock/unlock wires from the alarm/remote start unit it still unlocks the doors.
Date Posted: September 17, 2007 at 8:00 AM
If you start the car with the regular key does it lock upon starting then unlock when you turn off the ignition thats highly likely being that it is a gm if so thats just ignition controlled door locks from factory
Date Posted: September 17, 2007 at 9:20 AM
Hi, yes it does lock when it's put in gear and unlock when it's shut off, why does it unlock the doors when I try to remote start it? thanks, Brad
Date Posted: September 17, 2007 at 12:13 PM
there are 2 ignition wires and I was told to just hook 1 of them up and was told that it didn't matter which 1 it was( I now have them both hooked up 1 going to the ignition and the 2nd wire going to ignition 2), was I told correct? the only wire that I'm not sure about is the wire that goes from the control unit to the door trigger I hooked that wire to the only blue wire that is connected to the headlight switch and it was a negative wire.   Here is what happens when I try to start it with the remote, the instrument lights come on in the dash, I hear the fuel punp then it shuts off and unlocks the doors because it shuts off the ignition. I have tried to remote start it with the key in the ignition and that doesn't help, it will start if I do it manually by turning the key. One more thing, I checked to see if it was sending voltage to the starter and it is NOT, it shuts down before doing that.
Date Posted: September 17, 2007 at 2:18 PM
If the system doesn't start with the key in the ignition and if the starter wire isn't putting out voltage then there is a problem with the remote starter
Date Posted: September 17, 2007 at 2:23 PM
the main unit shuts off before it sends voltage to the starter, I can only see 3 wires that have anything to do with shutting down the main unit.....the hand brake wire, grounded.....door trigger wire.....foot brake wire...I tested the hand brake ground and foot break wire and they are hooked up correct, the door trigger wire is supposed to be negative and there is no power to it.
Date Posted: September 17, 2007 at 2:28 PM
Well the door pin shouldn't prevent the starter from turning over if anything it would stop the system from turning on at all. If there is only one blue wire at the headlight switch then it should be it does you dome light work or do you have a dome light override switch or button. Because that could cause problems with the system. On another note if the dome light bulb is burnt out that could also be a problem.
Date Posted: September 17, 2007 at 2:41 PM
the dome lights come on when the doors open so that shouldn't be the problem, that narrows it down to the the brake wires and they check out ok.
Date Posted: September 17, 2007 at 2:53 PM
Did you hook up and program the tach wire? Do you have a link to the manual or could you e-mail it to me chadwa2003@yahoo.ca
Date Posted: September 17, 2007 at 5:24 PM
I hooked up the tach wire (they call it in their words HIGH VOLTAGE COIL STARTER )and checked to make sure that it was getting power(low voltage) .I didn't have to program anything but the bypass for vats. the manual is nothing more than a connection diagram, there are no real instructions, no trouble shooting tips or anything.
Date Posted: September 17, 2007 at 8:04 PM
thanks for all the help, I'm giving up on this unit, there is nothing that I can do to make it work. Is commando a good company to buy from, I checked their website and atleast I can read it lol and they have an 800# for tech support. thanks again, Brad
Posted By: wrenches
Date Posted: September 17, 2007 at 9:02 PM
You don't have the unit set up to work in a manual transmission car do you?
Date Posted: September 17, 2007 at 9:15 PM
no, it's in an automatic tranny
