1999 silverado alarm problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=97326
Printed Date: April 30, 2026 at 5:57 AM
Topic: 1999 silverado alarm problem
Posted By: whitextreme
Subject: 1999 silverado alarm problem
Date Posted: September 21, 2007 at 4:46 PM
I recently bought a 1999 Silverado that has a factory alarm and also has a DEI 4200 remote start installed.  The problem that I am having is that the alarm will only arm if I lock the doors from the keypad with the drivers door open.  Is this normal or is there something that I should be checking out?
Posted By: dswift
Date Posted: September 21, 2007 at 5:52 PM
umm dude thats your factory alarm bro
"dont ground out!"
Date Posted: September 21, 2007 at 9:08 PM
The factory alarm only works if you lock it with the door open?
Posted By: xtremej
Date Posted: September 22, 2007 at 11:02 AM
yes, or with the factory remote.
Posted By: xtremej
Date Posted: September 22, 2007 at 11:03 AM
Correction you could also pusle the the driver door pin when you lock it, this would arm the factory alarm
Date Posted: September 24, 2007 at 3:09 PM
Ok that makes sense thank you for the help
