1999 gmc sierra diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=97350
Printed Date: April 19, 2026 at 2:23 AM
Topic: 1999 gmc sierra diagram
Posted By: Alpine Guy
Subject: 1999 gmc sierra diagram
Date Posted: September 22, 2007 at 6:52 PM
Can someone please post a wire diagram for a 1999 GMC Sierra for remote start/alarm. The one on this site is partially wrong.
Posted By: rudydapimp
Date Posted: September 22, 2007 at 7:28 PM
12volts      red       + ignition harness
Starter      yellow + ignition harness
Second Starter
Ignition pink + ignition harness
Second Ignition      white       + ignition harness
Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Third Ignition
Accessory      orange + ignition harness
Second Accessory
Keysense
Power Lock lt. blue + brown plug at BCM
Notes: The BCM is located behind the drivers side of the dash. The plugs on the BCM face towards the rear of the vehicle. The parking lights are in pin A5 and the headlights are in pin A11.
Power Unlock     white + brown plug at BCM
Lock Motor      gray             driver kick panel
Unlock Motor     tan       driver kick panel
Parking Lights+      brown       + lt. blue plug at BCM
Parking Lights-      white       -       lt. blue plug at BCM
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger -       BCM
Notes: Use tan for the drivers door located in pin B4 of the purple plug, and for the passenger door it will be a orange in pin B2 in the purple plug or dk.blue/white in pin B11 of the lt.blue plug, must diode isolate these wires.
Dome Supervision
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm      lt. green - driver kick panel
Notes: Also found in the purple plug of the BCM.
Disarm No Unlock
Tachometer white ac ECM
Notes: ECM is located near the battery, down low, between the fender and the fan under the black plastic cover. On the 4.3L, the tach wire is at pin 20 in the connector labeled red. On the 4.8L, 5.3L, and 6.0L, the tach wire is located at pin 10 in the red connector.
Wait to start      dk. blue       -       instrument cluster
Notes: See DirectFax document 1090.
Brake Wire      white       +       brake pedal switch
Parking Brake
Horn Trigger      black       -       brown plug at BCM
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module:      Category:
Combo Interface      Required:
No      Type:
Data Bus
Part #: 1700G
Alternate Part1 #: 457GW
Notes: Can use the 1700G or 457GW to bypass the Passlock II, but it will not control the door locks on this model year.
Immobilizer Bypass      Required:
Yes      Type:
Passlock II
Part #: GMBP
Alternate Part1 #: PLJX
Alternate Part2 #: 556LW
Alternate Part3 #: 555LW
Alternate Part4 #: DesignTech 20402
Alternate Part5 #: DesignTech 29402
Notes:
Smart Starter Kill Relays: Not Available
Date Posted: September 22, 2007 at 7:41 PM
Thank you very much
