stratus wire starter kill
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=97486
Printed Date: April 18, 2026 at 3:56 PM
Topic: stratus wire starter kill
Posted By: flint28no
Subject: stratus wire starter kill
Date Posted: September 27, 2007 at 3:38 PM
I just bought a VIPER alarm, i'm a bit confused about the wiring of the starter kill relay.  Wires on the starter kill relay are GREEN, BLACK, 2 YELLOWS connected to each othe one goes to the ALARM Harness and one is loose, ORANGE goes to the alarm harness.
The manual says Green wire from the Pre-Wired starter kill relay goes to the ignition harness and the black goes to the starter motor, whick wire do i use in the ignition harness for the green wire on the starter kill relay?
Ignition wire harness
Constant 12V+Red or Pink/Black or RED / Blue Ignition Switch Harness
StarterYellow Ignition Switch Harness
IgnitionDark Blue Ignition Switch Harness
Ignition 2Dark GREEN/ Red Ignition Switch Harness
Ignition 3BLACK/ White Ignition Switch (Power, Heat
The manual says also that the yellow wire should be connected to the ignition system. is this the Dark blue on this table?  and the black wire from the starter kill relay that supposed to go to the starter motor, can i use the yellow wire in the ignition harness for this?
I made some drawing of how i understand it. Can someone help me to point  were to connect the wire from the relay to the ignition harness ?
THE IMAGE I MADE
https://www.bicoluragon.com/wiring2.jpg
Posted By: techman93
Date Posted: September 29, 2007 at 1:38 PM
For starter kill.
You must cut yellow wire and the side that comes from the "key side" gets connected to the green wire then the other side gets connected to the black wire. The yellow ignition wire then gets connected to the dark blue wire. That will energize the coil of the relay and make it so when the alarm is armed, the starter wire will not get 12v supply.
Date Posted: September 29, 2007 at 1:40 PM
and orange goes to the (-) output wire on alarm, normally the same color of orange
Date Posted: October 05, 2007 at 1:40 PM
Thanks a lot, 4 your help i got it working now :))posted_image
