03 ford f250
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=9749
Printed Date: April 03, 2026 at 10:41 AM
Topic: 03 ford f250
Posted By: zargon
Subject: 03 ford f250
Date Posted: February 19, 2003 at 12:53 PM
we installed a dei remote start on a ford f 250 with out anti thefton the key, it works fine except for the first thing in the morning, we are in tach mode and our unit learned tach, i,m going in to check my power and ground connections, i did not fire up all the accessorie wiresonly the gray and yellow , i did check and the heat and alternator are turning on anyone have a comment, thanks
Posted By: Velocity Motors
Date Posted: February 19, 2003 at 1:39 PM
Bad relay ?? Did you use one for the ACC wires?
