remote start wires
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=97538
Printed Date: April 18, 2026 at 10:49 PM
Topic: remote start wires
Posted By: andym1999
Subject: remote start wires
Date Posted: September 29, 2007 at 9:01 PM
Hi... just wondering if I am able to cut off the extra wires on my wire harnesses that are not needed.
Posted By: techman93
Date Posted: September 29, 2007 at 10:54 PM
On the harness on the remote start you can cut the wires you don't need but make sure they are cut at slightly different lengths so they don't happen to cause a problem by touching later, and I usually wrap with tape to keep neat. Eliminating unused wires will make it easier to keep track of what you have left to connect. I solder all my connections so they don't have any chance of coming apart or it having a loose connection that will cause arcing inside the module. T-taps stink so I don't use them.
Posted By: howie ll
Date Posted: September 30, 2007 at 4:46 AM
Techman is spot on, I pre-prepare on bench if I can, solder and insulate (heat shrink) install Siren, extra switches if necc. external sensors antenna all borught back to place of (stealthfully) mounting CPU then I have to rejoin the ones I've cut off by error so the other practice is to discreetly bundle unused wires!
Date Posted: September 30, 2007 at 7:46 AM
Thanks guys.
Posted By: Chris Luongo
Date Posted: September 30, 2007 at 1:10 PM
Also, and especially if this is the only unit you have..........that is, if you're not a retailer with another shelf full of the same kind of remote starter.........it's a good idea to leave a couple of inches of wire, so if later on you need/decide to connect that wire to the car, you can still splice on an extension.
Posted By: howie ll
Date Posted: September 30, 2007 at 2:06 PM
Chris is exactly right, how often had I had to reinstall my own alarms in another vehicle OR the customer has come back for more so why did I cut that aux wire too short!
