additional sensors
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=9768
Printed Date: April 02, 2026 at 9:21 PM
Topic: additional sensors
Posted By: dyer
Subject: additional sensors
Date Posted: February 19, 2003 at 7:32 PM
I want to add a glass break sensor to my alarm. However, I don't see a (-)input on my alarm for additional sensors. It already has a plug in shock sensor, but thats it. What can I do to add the glass break sensor?
Posted By: BNLUIS
Date Posted: February 19, 2003 at 8:00 PM
Wposted_image What kind of alarm do you have and what sensor are you tryning to put ( Make )
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
Posted By: dyer
Date Posted: February 20, 2003 at 6:02 AM
Crimestopper alarm and probably commando glass break sensor.
Posted By: Two_Cold
Date Posted: February 20, 2003 at 12:08 PM
I splice the shock sensor and proximity sensor together on the same input all the time. I would try to splice the glass break sensor with the shock sensor. Test it first with a volt meter to make sure you are not shorting anything out first.
You may need a relay if one is + output and the other is -, but that is easy to do.
