2005 gmc 2500 diesel 4dr.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=97701
Printed Date: April 22, 2026 at 11:32 AM
Topic: 2005 gmc 2500 diesel 4dr.
Posted By: habco1
Subject: 2005 gmc 2500 diesel 4dr.
Date Posted: October 05, 2007 at 10:26 AM
I installed an SR6000 into a 2005 GMC  4dr diesel and the door locks have stopped working all the doors only the driver side works for lock and unlock. I tested the wires in the door module when I installed them and came to the conclusion that they were 4 wire alternating. The info sheet for the wire colors says it should be 5 wire but one leg did not rest at ground. The switches and the key faubs all work fine and there is signal on the output lines from the relays when the switches are pressed. Does anyone have any in sight into this problem.
Posted By: extreme1
Date Posted: October 05, 2007 at 10:46 AM
umm, you didn't use a data module for locks?
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Posted By: habco1
Date Posted: October 05, 2007 at 11:17 AM
I recommended the 456G or 457G module for his truck but the guy is very cheap and did not want to buy it. I do not have access the directfax 1601 document to find out the other way of connecting them. ( I am interested in becoming a dealer so I can get these documents.) Should I make him use the data module?
Posted By: KarTuneMan
Date Posted: October 05, 2007 at 11:15 PM
Yes. I wouldn't EVEN do this rig with keyless entry without it!
Posted By: habco1
Date Posted: October 06, 2007 at 12:24 AM
Thanks. I do have one question though. Is it possible to become a DEI dealer even if you don't own a store. I have been doing starters for about 15 years, most of it while working at a professional install shop. Now I just do about 30-40 a year mostly around Christmas time. It would be nice to specialize in a certain brand of starter and from what i have seen from DEI their products are really good. I usually tell my clients just to buy which ever one they want and I put it in so I have done them all. With the new generation of vehicles it would be nice to get better at one brand and just sell these to future clients. Can you tell how this might be accomplished? Thanks again, your help is always welcome.
Date Posted: October 06, 2007 at 9:34 AM
Get yourself a business licence. Alot of the DEI line is available to what are called expeditors, thru stocking distrubutors.
Hornet, Automate etc.   See my sig. Astroflex was purchased by DEI almost 2 years ago. Their product line has changed, and the top dog in the lineup now resembles a DEI unit.
www.astroflex.com    another option.
Posted By: extreme1
Date Posted: October 06, 2007 at 8:07 PM
457G does both locks and bypass.
We only use data for 03+ trucks for bypass.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Posted By: habco1
Date Posted: October 16, 2007 at 1:19 PM
Thanks for the help guy's
