dei 24921 parking light flash
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=97770
Printed Date: April 24, 2026 at 8:50 AM
Topic: dei 24921 parking light flash
Posted By: USMC Vet
Subject: dei 24921 parking light flash
Date Posted: October 08, 2007 at 4:22 PM
It says in the manual that the whole time the remote start is active the parking lights will flash,if you hook them up. But I do not want them to flash continuously. What does this mean ? Why would they have them flash the whole time ?
Posted By: KarTuneMan
Date Posted: October 08, 2007 at 4:55 PM
You should also be able to program them to stay on "solid" while remote started.
Posted By: Twelvoltz
Date Posted: October 08, 2007 at 6:24 PM
I just went to their website and checked, it looks as if DEI has branded their "Boa" systems under the "Ready Remote" line after they acquired Designtech. I hate to be the bearer of bad news, but switching the parking lights to solid (not flashing) is not a programmable option on that system. What is the make/model/year of the vehicle? If the parking light flash bothers you, you could use the status output to turn the parking lights on.
------------- Installer, IT support, and FFL. I need less hobbies.
Posted By: techman93
Date Posted: October 08, 2007 at 8:18 PM
As with any remote unit if there isn't a wire for it it is always possible to configure one by relay usage. As noted a negative staus wire or an ignition wire diode isolated with a relay. Just depends how you want to hook it up.
Posted By: USMC Vet
Date Posted: October 08, 2007 at 9:00 PM
It's a 2007 Ford Fusion.
