upgrade alarm to remote start?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=978
Printed Date: March 31, 2026 at 1:42 AM
Topic: upgrade alarm to remote start?
Posted By: dyer
Subject: upgrade alarm to remote start?
Date Posted: May 27, 2002 at 6:17 PM
Can I later upgrade any alarm to have remote start?
Dyer
Posted By: Chris Luongo
Date Posted: May 27, 2002 at 9:29 PM
Yes, absolutely.  You can even buy remote starts that will run right off a car's factory keyless entry.  But the results can vary.
There are a few extra issues the installer will have to deal with, namely, re-wiring a few things to keep the alarm from going off during remote starting.  They could wire in a relay to interrupt your alarm's shock sensor, but more often than not, they just unplug the sensor or turn it all the way down.
Also, if it's set up to trigger off your existing alarm's remote, the range will suck.  Or, you'll have to carry two remotes around.  If you buy the alarm and remote start from the same brand, a good installer can program one remote to operate both units directly, which would be best.
So, you can do it, but it's a pain, and it will probably cost you a little more in the end...better to just buy a combo unit all at once.
Posted By: dyer
Date Posted: May 28, 2002 at 8:00 AM
thank you
Dyer
