96 ford contour horn amperage
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=97902
Printed Date: May 16, 2026 at 6:06 PM
Topic: 96 ford contour horn amperage
Posted By: joemama1967
Subject: 96 ford contour horn amperage
Date Posted: October 12, 2007 at 12:23 PM
Does anyone know how much power is drawn from the horn? I don't know if the horn wire is using a relay or not. It might even be a simple latch. Just wondering if anyone knows what the amperage might be. The "Panic" uses a 400mA ground.
--Ed (the guy who hates relays because that is just one more item that can fail)
Posted By: howie ll
Date Posted: October 12, 2007 at 2:14 PM
A single horn draws about 10amps,  airhorns 20, most Japanese cars use a relay and the feed at the steering column is a low current neg.(Check) Thus relay not required.
Posted By: howie ll
Date Posted: October 12, 2007 at 2:16 PM
PS Sorry your vehicle is a Ford Mondeo, it used pos supply from switch, no relay but the fuse would have a "horn" icon, check that, it would be the consumption.
Posted By: usabuilt
Date Posted: October 12, 2007 at 2:22 PM
hmm..I got a BLACK/ blue at steering column negative? should not need any relay.
Date Posted: October 12, 2007 at 2:34 PM
usabuilt said: hmm..I got a BLACK/ blue at steering column negative? should not need any relay.
Yes, but what is the amperage at that point when you honk the horn?
Thanks for everyone's input
Posted By: usabuilt
Date Posted: October 12, 2007 at 2:37 PM
put your current meter inline with the positive going to the car horn and honk it..this will give exact measurment.
