01 mustang pats bypass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=98129
Printed Date: May 14, 2026 at 2:06 PM
Topic: 01 mustang pats bypass
Posted By: sbessettejr
Subject: 01 mustang pats bypass
Date Posted: October 19, 2007 at 11:03 PM
I am installing a viper remote start, and have the 1100f ford PATS interface. I see on the drawing they have GRY/RED connecting to ECM TX, and GRN/RED connecting to ECM RX. Where are these wires located in the vehicle and what colors are they? Also if you have a location for ground when running it would be most helpful.
Posted By: KarTuneMan
Date Posted: October 20, 2007 at 12:56 PM
 REVERSE LIGHTS BLACK/ pink At GEM module above DKP   +
 DIMMER Dk.blue/white At light switch harness   +
 VSS WIRE WHITE/ orange Pin-68 at PCM in right kickpanel   8000ppm
 TRANSPONDER IGNITION WHITE/ lt.blue 4 pin connector ( near steering column)   +
 TRANSPONDER DATA 1 Gray/orange 4 pin connector ( near steering column)   DATA
 TRANSPONDER DATA 2 WHITE/ lt.green 4 pin connector ( near steering column)   DATA
 TRANSPONDER GROUND BLACK/ white 4 pin connector ( near steering column)   -
