infinity qx56 trunk, starter issue
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=98146
Printed Date: May 14, 2026 at 1:02 PM
Topic: infinity qx56 trunk, starter issue
Posted By: driep
Subject: infinity qx56 trunk, starter issue
Date Posted: October 20, 2007 at 8:38 PM
Hello all,
I am not a distributor, nor an installer, but rather an end user. I am hoping someone has seen this, and possibly has a solution, as my installer is out of ideas.
I just purchased, and had installed a Compustar CM330 starter on my Infiniti QX56, and they used the iDataLink ADS AL 32.
Everything works great except the hatch, and I am hoping someone can tell me if they have done a similar install, and if the following is possible.
The QX56 has both a glass hatch release, and a trunk (tailgate) release. Currently, when I press the trunk release button on my starter, it activates BOTH the window release, AND the tailgate opens as well, which is quite annoying. When I press it again, it closes the tailgate, but again, pops open the window hatch.
I am HOPING that this unit can simply just activate / open the tailgate alone (not the window hatch), and when pressed again, it will activate it again (which would close it).
Anyone seen this? Anyone have a solution that I can take back to my installer so we can make this work correctly?
Thanks all!
Posted By: KarTuneMan
Date Posted: October 21, 2007 at 1:17 AM
Is the release and close option being triggered thru the i-data module? The only thing I have is from the Astrochart. A negative pulse on a blue/white at the switch that opperates the hatch door.
Posted By: tedmond
Date Posted: October 21, 2007 at 7:08 AM
maybe it requires double pulse to open one and single for the other. I got negative YELLOW/BROWN (-) right of steering collumn from scytek wiring database. member to always probe your wires with a DMM
