wires into doors, molex plug
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=98252
Printed Date: May 13, 2026 at 10:09 PM
Topic: wires into doors, molex plug
Posted By: ikethegoalie
Subject: wires into doors, molex plug
Date Posted: October 23, 2007 at 5:44 PM
Ok, I have read about how on most molex plugs you just find an empty corner and drill a hole, but here is my predicament, I do not think all the wires I need to run are going to fit.
is there a way I can run new wires into the door and install a new rubber grommet?
Posted By: init
Date Posted: October 23, 2007 at 9:36 PM
You may be able to install additional boot so that you can run the wires you need. What car do you have? Maybe if you post that information, we'll find someone here who's had a similar experience. ------------- I'm not a professional installer. But I did stay at a Holiday Inn Express.
Date Posted: October 23, 2007 at 10:37 PM
it is a 2006 chevrolet colorado crew cab, do you know where i can find door jamb boots?
Posted By: extreme1
Date Posted: October 23, 2007 at 11:50 PM
it takes a bit of work but you can accually get 2 x12awg speaker wire through the boots. ------------- Shaughn Murley
Visions Electronics
Red Deer, Alberta
Date Posted: October 24, 2007 at 8:02 AM
what about 2x 12awg, 2x 18awg, and 1x 16awg speaker wire ;-)
Posted By: extreme1
Date Posted: October 24, 2007 at 9:11 AM
truck have power locks and windows?
if yes then you're screwed, if not no problem.
the trick is removing the boot, unplugging the molex and doing a little surgury on the housing to allow extra wire inbetween the 2 plugs.
Visions Electronics
Red Deer, Alberta
Date Posted: October 25, 2007 at 9:19 AM
well, i did the driver door last night and going through the molex plug was not nearly as bad as it could have been.
Posted By: extreme1
Date Posted: October 25, 2007 at 10:08 AM
yeah, the new fords are impossible, as are the new VW/Audi's. on my 06 Jetta I bought a wire repair kit and pinned the empty spots on my molex for speaker wire.
Visions Electronics
Red Deer, Alberta
