03 ml350 and matrix 50.5x
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=98274
Printed Date: May 14, 2026 at 6:25 AM
Topic: 03 ml350 and matrix 50.5x
Posted By: sasa929
Subject: 03 ml350 and matrix 50.5x
Date Posted: October 24, 2007 at 7:22 AM
Does anyone have complete install for this vehicle. Some people says it is not possible for remote start to be done, some peple says yes. Please if anyone have accomplished this let me know. Thanks,
Posted By: profuse007
Date Posted: October 24, 2007 at 10:53 AM
No, maybe 2003 ML350* doesnt exist?
------------- Houston,TX
Posted By: howie ll
Date Posted: October 24, 2007 at 10:54 AM
If you have a laser key give up now otherwise it's possible.
Posted By: howie ll
Date Posted: October 24, 2007 at 10:55 AM
Do you mean ML 320?
Posted By: sasa929
Date Posted: October 24, 2007 at 12:45 PM
Well Mercedes ML320 and 350 are the same cars only engine is differnt. 3.2 and 3.7
Posted By: sasa929
Date Posted: October 24, 2007 at 12:50 PM
And i don't have a laser key. Just regular mercedes fobe with flip key. Thanks,
Posted By: howie ll
Date Posted: October 24, 2007 at 4:20 PM
Ok search this site there was a posting on this topic a month ago or consult the alarm manufacturer's web sight.
Date Posted: October 24, 2007 at 6:39 PM
Use universal bypass, 555U or 556U.
Heres the diagram and judge it for yourself. There arent too many installation on German cars, Benz or BMW, on this board.
Battery RED (+) IGNITION SWITCH HARNESS
Ignition 1 GRAY (+) IGNITION SWITCH HARNESS
Ignition 2 TAN (+) IGNITION SWITCH HARNESS
Starter 1 WHITE (+) IGNITION SWITCH HARNESS
Key Sense ORANGE
Tachometer VIOLET/WHITE (-) AT IGNITION COIL
Parking Lights LIGHT GREEN (+) AT VEHICLE FUSE PANEL
Brake Lights BLACK/ RED (+) AT SWITCH ABOVE BRAKE PEDAL
Power Unlock GREEN & PINK (REV) IN HARNESS NEAR FUSEBOX UNDER HOOD
PowerLock WHITE (REV) IN HARNESS NEAR FUSEBOX UNDER HOOD
LF Latch GRAY (-) AT KEYLESS ENTRY MODULE NEAR VEHICLE FUSEBOX UNDER HOOD
RF Latch GRAY (-) AT KEYLESS ENTRY MODULE NEAR VEHICLE FUSEBOX UNDER HOOD
LR Latch WHITE (-) AT KEYLESS ENTRY MODULE NEAR VEHICLE FUSEBOX UNDER HOOD
RR Latch WHITE (-) AT KEYLESS ENTRY MODULE NEAR VEHICLE FUSEBOX UNDER HOOD
Posted By: sasa929
Date Posted: October 24, 2007 at 11:20 PM
Thanks, this is the answer that i locking for.
