05 volkswagen jetta fact remote prog.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=98285
Printed Date: May 14, 2026 at 11:29 AM
Topic: 05 volkswagen jetta fact remote prog.
Posted By: alariskirein
Subject: 05 volkswagen jetta fact remote prog.
Date Posted: October 24, 2007 at 1:16 PM
hi there: i need help to program a factory remote for a 05 volks jetta. i just install a ignition cut device and works fine the problem is that after a 2-3 weeks the factory remote stop working .the factory alarm arms and disarm with the driver door . so i know is not a blown fuse. please help . the remote led turns on when i press a button . i already replaced the battery. any help will be appreciated.
Posted By: howie ll
Date Posted: October 24, 2007 at 4:14 PM
The factory remote has gone out of synch with factory immobiliser, it's not your fault, it's very common unfortunately it has to be reprogrammed by a dealer.
Posted By: reisset
Date Posted: October 25, 2007 at 10:53 AM
Find a VAG COM, you can by a cable on EBAY. With this tool you will be able to reprogram, and diagnose you VW :)
Enjoy
reisset
Date Posted: October 25, 2007 at 5:39 PM
ok. that´s what i read on the owners manual . and it show how to reprogram ( sync) with the inmobilizer . i made it the way it should be and nothing . i´ll tell the customer to take the car to the dealer. thank you anyway guys.
