adding horn honk and flashing headlights
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=98353
Printed Date: April 02, 2026 at 5:10 AM
Topic: adding horn honk and flashing headlights
Posted By: logixz
Subject: adding horn honk and flashing headlights
Date Posted: October 26, 2007 at 6:40 PM
I have a python 881xp and would like to add horn honk and flashing headlights only when the alarm is triggered. I dont want the horn and headlights to turn on during arm and disarm. Which outputs can i use to do this? What is the relay setup?
Posted By: enice
Date Posted: October 26, 2007 at 9:49 PM
Depending on the year you got the 881xp it would be a brown 2 pin plug that goes on the side of the alarm. This is the horn honk output and only goes off during the triggers. You can diode isolate that wire and tie it into your headlights as well.
Posted By: logixz
Date Posted: October 31, 2007 at 4:51 PM
The model I have doesn't have a brown 2 pin plug? How do I add horn honk and flashing headlights to this system?
Posted By: profuse007
Date Posted: October 31, 2007 at 7:12 PM
turn off the arm/disarm chirp? not sure if thats possibel but look in the pogramming.
------------- Houston,TX
Posted By: Twelvoltz
Date Posted: October 31, 2007 at 8:47 PM
It is a brown wire in a 2-pin plug with a ORANGE / black wire right next to it, not a brown plug.
Relay pin 85: Brown horn trigger from 881
Relay pin 86 and 87a: Constant fused +12V (heavy enough to power the lights)
Relay pin 30: Out to headlight +12V turn on
Brown wire will also go to the horn trigger with a diode inserted to prevent feedback to the relay. This is of course assuming your vehicle has a negative trigger horn button(most do). Since you do not mention the make/model/year of the vehicle we can only assume it is in the majority.
------------- Installer, IT support, and FFL. I need less hobbies.
Posted By: logixz
Date Posted: November 01, 2007 at 1:03 AM
I have an older 881xp module that doesnt have a dedicated horn honk and 6th channel. I want to keep the arm and disarm chirp. When triggered, have the siren, horn honk and headlights flash. How can I add horn honk and flashing headlights using the other output wires with diodes and relays?
