98 Accord factory disarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=9844
Printed Date: April 01, 2026 at 2:39 PM
Topic: 98 Accord factory disarm
Posted By: speekafreak
Subject: 98 Accord factory disarm
Date Posted: February 21, 2003 at 6:28 AM
Can someone tell me how to disarm the factory alarm on a 98 Accord? I have installed a Python 1500 remote start and everything works good. Just the damn factory alarm goes off sometimes when you disarm the Python. Any help will be appreciated.
Posted By: Velocity Motors
Date Posted: February 21, 2003 at 8:10 AM
This topic has come up alot....... did you not try to do a search on this topic ?
Here is a particular post that may answer your question: https://www.the12volt.com/installbay/forum_posts.asp?tid=5805&KW=1998+Accord+Disarm
Date Posted: February 21, 2003 at 12:35 PM
Yes, I did search but only in Security. Thanks for the link.
Date Posted: February 21, 2003 at 12:58 PM
No problemo....... if you have any more questions about this topic, just post them posted_image
Posted By: jrilla
Date Posted: February 21, 2003 at 2:08 PM
If you are not interested in going into the door, you can try to find a yellow wire behind the glove box, but there are a few so you may have to do some trial and error. You need to use a relay to open the circuit which will disarm the alarm.
J Rilla
Owner/Installer
Posted By: profuse007
Date Posted: February 21, 2003 at 10:26 PM
hey jrilla, what is the different b/t the one behind the glove and the door. you mention using a relay, how does that work?
i had to do the hard way to get to the disarm wire last time.
