thor remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=98563
Printed Date: May 08, 2026 at 9:56 PM
Topic: thor remote start
Posted By: slobs03031980
Subject: thor remote start
Date Posted: November 02, 2007 at 8:08 PM
I bought a thor cf427 remote start for my 2000 caravan.  What a terrible product first off.  The instructions are badly translated.  So back to my problem.  I installed it today and got everything working except for the remote start(the only thing I wanted) and the parking lights.  The parking lights i am not concerned with, but the start I am.  Everything is hooked up and I triple checked every conection and wire with a wire diagram for this car and everything is correct.  All it does when I push the button is the 1st ignition will come on for about 3-5 sec then turn off.  it never gets to ingnition #2 or start.  Any Help would be appriciated!!!!!xx(
Thanks Rob Ferg
R Ferg
Posted By: Twelvoltz
Date Posted: November 03, 2007 at 7:16 AM
I have never installed a Thor system however does the system use external or internal relays? I have found that with some of the systems that use external relays the harness that connects to the external relay pack can easily become unplugged.
Did your system come with an anti-grind relay? If it did make sure you do not have it backwards.
Both ignitions should energize at the same time, I would assume you mean the accessories never energize. I have seen some of the imported systems that do not energize accessories until after started.
Posted By: tedmond
Date Posted: November 03, 2007 at 7:40 AM
hey man, if you still ave a chance to return the alarm, you should consider looking at this
https://www.automotiveforums.com/t199542.html
