alarm, power door lock, 03 f250
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=98578
Printed Date: May 09, 2026 at 2:37 AM
Topic: alarm, power door lock, 03 f250
Posted By: rkfguard
Subject: alarm, power door lock, 03 f250
Date Posted: November 03, 2007 at 4:24 PM
ive hooked up an alarm to my truck that has factory keyless entry..when i hook up the alarm, my door switches dont work immediately. so i dont think it has GEM...without the alarm, i lock the doors, that after several minutes, reach inside the window to unlock using the switch and it works..so according to the directions on how to test for GE M, i do not have it..what would cause the door switches not to work..
Posted By: KarTuneMan
Date Posted: November 04, 2007 at 12:17 AM
The bcm, gem, whatever you want to call it, is "goin to sleep" it powers down.
You can shut that feature off. Try this.
get in the truck, all doors closed turn on ign. hit unlock 3 times on the door switch. THEN, turn ign. off, hit unlock 3 times, THEN, turn ign. on, hit lock 2 times.... you should hear 2 horn honks. Done!
The bcm, now, will not go to sleep.
