viper 791xv not unlock doors while rs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=98618
Printed Date: May 10, 2026 at 4:03 AM
Topic: viper 791xv not unlock doors while rs
Posted By: nonstopboost
Subject: viper 791xv not unlock doors while rs
Date Posted: November 04, 2007 at 12:56 PM
So i just installed a Viper 791 in my 08 Scion xb. everything works great other than when the car has been remote started then i hit unlock. the alarm deactivates but the doors do not unlock. they do unlock normally. please any help??
Posted By: KarTuneMan
Date Posted: November 04, 2007 at 1:29 PM
Factory transmitter.....right?
Doesn't work (but you knew that) and it won't......
Get a unit and use that units transmitters.... It'll work every time!
Date Posted: November 04, 2007 at 1:51 PM
I am using the Viper 791 trasmitter to try to unlock and lock it. IT works normally. but never works when its remote started!
Posted By: enice
Date Posted: November 04, 2007 at 1:56 PM
which wires did you use for the lock and unlock wires.???
Date Posted: November 04, 2007 at 2:31 PM
lock=blue
unlock-pink
located in the kick panel
they door locks work great when the car is just at sit...the problem occurs when it is remote started.
