pink wire on compustar pro starter
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=98647
Printed Date: May 12, 2026 at 2:09 PM
Topic: pink wire on compustar pro starter
Posted By: hankblas
Subject: pink wire on compustar pro starter
Date Posted: November 05, 2007 at 10:47 AM
I have all the wires marked where they have to go except the Pink slave timer start wire. Do I need this wire for my car a 2003 Acura EL factory alarm and keyless entry. Thanks
Posted By: hankblas
Date Posted: November 05, 2007 at 10:48 AM
i forgot to ask where it goes
Posted By: usabuilt
Date Posted: November 05, 2007 at 12:09 PM
Sounds like it goes to a timer which would send it a negative pulse to start the car at certain time intervals, (not sure though), but if that is its function it would not be required unless you have a timer.
Posted By: hankblas
Date Posted: November 05, 2007 at 12:58 PM
I forgot to mention that on the compustar install manual it says the the pink wire "is most commonly used when adding a remote start to a factory keyless entry system. You can adjust the number of pulses with option 2-4"
Posted By: usabuilt
Date Posted: November 05, 2007 at 1:34 PM
then that wire would not be needed if you are using Compustar remotes,make sure you tape the wire, because a ground on that wire WILL cause the remote starter to activate.
Posted By: usabuilt
Date Posted: November 05, 2007 at 1:38 PM
forgot to mention if you are using your factory remotes to start your car you can tie this wire to the unlock wire in your car and set it for 2 or 3 or 4, which means if you press your unlock either twice or three times or 4 times it will also activate the remote start...be sure to use a relay on the unlock wire also.
Posted By: usabuilt
Date Posted: November 05, 2007 at 1:40 PM
I should have said tie it to your lock wire..sorry..I need more coffee.
Posted By: hankblas
Date Posted: November 05, 2007 at 2:42 PM
Thanks for the help
