04 gmc truck remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=98651
Printed Date: May 12, 2026 at 12:01 PM
Topic: 04 gmc truck remote start
Posted By: exciter88
Subject: 04 gmc truck remote start
Date Posted: November 05, 2007 at 11:52 AM
Put an autostart 1155TL on a 2004 serria diesel. I am using the factory remote horn honk to start the truck,  black wire . Problem is the truck only starts when I press the horn button and does not start when using the factory remote (horn does sound). Problem #2 when it does start using the horn button it only runs about 5 sec. then shuts off, it will do this three times . I have no engine light or security lights. Using a desighntech 20402 bypass, I am sure I have the resistance set correctly and have changed the YELLOW /GREEN from ign 2 to ign 1 but no change. Ign 1 and 2 are connected and have power when in start. Any thoughts?
Posted By: Twelvoltz
Date Posted: November 05, 2007 at 12:45 PM
I would set the unit to require 3 pulses for activating and grab the actuator lock leg to trigger. Press lock 3x and the system will activate. If the system only has a negative activation input you will have to use a relay to change the polarity to negative.
As far as your shut down issue is concerned, it sounds as if the RS does not know the truck is running. I would set the unit to voltage sensing and set the crank time up to 1.5-2 seconds. The 04 GM truck platform has factory anti-grind, and over crank protection built in.
Date Posted: November 06, 2007 at 6:22 AM
 I have not had much luck triggering from doorlocks on gm's, that is why I went to the neg horn wire much simpler but of course not in this case.  I have done a few other chevys without any problems using the horn wire and 2 pulses. Never had the veihicle stop running after about 5 seconds. I will try to set the crank time up and see what happens. Thanks
