| Print Page | Close Window |
2007 outlander, remote start infoPrinted From: the12volt.comForum Name: Car Security and Convenience Forum Discription: Car Alarms, Keyless Entries, Remote Starters, Immobilizer Bypasses, Sensors, Door Locks, Window Modules, Heated Mirrors, Heated Seats, etc. URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=98736 Printed Date: May 11, 2026 at 5:30 AM Topic: 2007 outlander, remote start info Posted By: theronsmith Subject: 2007 outlander, remote start info Date Posted: November 07, 2007 at 7:01 PM Can anyone out there help me out with remote start info?
------------- chevy II Replies: Posted By: Twelvoltz Date Posted: November 07, 2007 at 7:55 PM Audiovox lists:
#513740: 2007 MITSUBISHI OUTLANDER 4DR SUV WITH 3.0L ENGINE AND 6-SPEAKER AUDIO SYSTEM Audio/Mobile Video WIRE COLOR POLARITY LOCATION Battery RED / WHITE (+) RADIO HARNESS Accesory YELLOW (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination GREEN / WHITE (+) RADIO HARNESS Power Antenna PINK (+) RADIO HARNESS LF Speaker (+) WHITE/ BLUE THESE WIRES ALSO GO TO THE FRONT LEFT TWEETER LF Speaker (-) BLACK/ BLUE RF Speaker (+) WHITE/ RED THESE WIRES ALSO GO TO THE FRONT RIGHT TWEETER RF Speaker (-) BLACK/ RED LR Speaker (+) YELLOW/BLUE LR Speaker (-) GRAY/BLUE RR Speaker (+) YELLOW/RED RR Speaker (-) GRAY/RED Steering Cntrls OPTIONAL Speed Cntrl NO Radio Security YES Security WIRE COLOR POLARITY LOCATION Battery YELLOW (+) IGNITION SWITCH HARNESS Ignition 1 WHITE (+) IGNITION SWITCH HARNESS Starter 1 ORANGE (+) IGNITION SWITCH HARNESS All Door Trigger USE EACH DOOR TRIGGER AND DIODE ISOLATE EACH WIRE Domelight Super YELLOW (-) AT VEHICLE FUSEBOX LF Latch YELLOW (-) AT MODULE UNDER DRIVER SIDE DASH RF Latch GREEN (-) AT MODULE UNDER DRIVER SIDE DASH LR Latch RED (-) AT MODULE UNDER DRIVER SIDE DASH RR Latch BLACK (-) AT MODULE UNDER DRIVER SIDE DASH Trunk Trigger WHITE (-) AT MODULE UNDER DRIVER SIDE DASH Hood Trigger RED / WHITE (-) AT MODULE UNDER DRIVER SIDE DASH Alarm Disarm GREEN/ RED (-) AT VEHICLE FUSEBOX Alarm Arm GRAY/BLUE (-) AT VEHICLE FUSEBOX Parking Lights YELLOW & BROWN (+) AT INTERIOR FUSE BOX HARNESS MUST USE BOTH WIRES AND DIODE ISOLATE EACH WIRE, Convenience WIRE COLOR POLARITY LOCATION Headlights-Lo RED / BLACK & ORANGE (+) AT EACH HEADLIGHT CAN ALSO BE FOUND AT UNDER HOOD FUSE BOX, MAY ALSO BE RED / BLACK & BLUE ON SOME MODELS All Hazrd Lights GREEN (-) AT MODULE UNDER DRIVER SIDE DASH Wipers-Lo GREEN (+) AT VEHICLE FUSEBOX Wipers-Hi BLUE (+) AT VEHICLE FUSEBOX Parking Brake LIGHT GREEN (-) AT VEHICLE PARKING BRAKE SWITCH Remote Start WIRE COLOR POLARITY LOCATION Battery YELLOW (+) IGNITION SWITCH HARNESS Ignition 1 WHITE (+) IGNITION SWITCH HARNESS Accessory 1 LIGHT GREEN (+) IGNITION SWITCH HARNESS Starter 1 ORANGE (+) IGNITION SWITCH HARNESS Key Sense RED / WHITE (OPEN) IGNITION SWITCH HARNESS THIS WIRE RESTS AT GROUND AND IS AN OPEN CIRCUIT WITH THE KEY INSERTED Tachometer GREEN / WHITE (AC) AT INJECTOR #1 ALSO AT ECM MODULE TO DRDIVER SIDE OF AIRCLEANER, PIN #2 Speed Sense WHITE/ BLUE (AC) IN HARNESS TO GAUGES Parking Lights YELLOW & BROWN (+) AT INTERIOR FUSE BOX HARNESS MUST USE BOTH WIRES AND DIODE ISOLATE EACH WIRE, Brake Lights RED (+) AT SWITCH ABOVE BRAKE PEDAL Reverse Lights WHITE (+) AT VEHICLE FUSEBOX Horn GREEN (-) AT VEHICLE FUSEBOX Modules WIRE LOCATION Please select another category Doorlocks/Windows WIRE COLOR POLARITY LOCATION Power Unlock RED / YELLOW (-) IN HARNESS IN DRIVERS KICKPANEL PowerLock WHITE/ BLACK (-) IN HARNESS IN DRIVERS KICKPANEL LF Window Up VIOLET (REV) AT DRIVER WINDOW SWITCH LF Window Dn ORANGE (REV) AT DRIVER WINDOW SWITCH RF Window Up BLUE/WHITE (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR RF Window Dn GREEN (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR LR Window Up WHITE (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR LR Window Dn BLUE (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR RR Window Up GRAY (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR RR Window Dn YELLOW (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation. ------------- Installer, IT support, and FFL. I need less hobbies. |
