turbo timer on concept 650 alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=98812
Printed Date: May 09, 2026 at 10:42 AM
Topic: turbo timer on concept 650 alarm
Posted By: jimcarman
Subject: turbo timer on concept 650 alarm
Date Posted: November 09, 2007 at 1:19 PM
Hi, i have a Clifford Concept 650 fitted to my Mk6 fiesta, the problem i am having, is that i cant find a wiring diagram for the turbo timer conversion. would anyone have a turbo timer diagram that is compatable with the Concept 650 alarm? any help would be very much appreciated, many thanks,
Posted By: benno56
Date Posted: November 14, 2007 at 3:11 AM
Hi Jim, Maybe you solved the problem already, but your solution is found in "download" on the home page of the 12 volt Regards benno
Posted By: howie ll
Date Posted: November 14, 2007 at 11:33 AM
Either WHITE/ blue aux 2,or RED / white, aux 1, whichever is unused, set on timer (install section) to 1 minute, feed to relay 85, Perm 12v+ to relay 87 and ign switch ,ign circuit before cuts to relay 86, feed "ign side alarm, cut and feed from original immobiliser cut to 87a and output to ign side to relay 30. Pressing aux 1 or 2 just before turning off engine will keep engine running for 1 minute. You can still operate alarm normally.
