2008 mitsubishi lancer evolution x
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=98944
Printed Date: April 17, 2026 at 3:58 PM
Topic: 2008 mitsubishi lancer evolution x
Posted By: sicbomb
Subject: 2008 mitsubishi lancer evolution x
Date Posted: November 13, 2007 at 5:03 AM
I just purchased the 2008 Mitsubishi Lancer Evolution X which has the Mitsubishi version of the Smart Key called the "Keyless Operation System".  The system includes a smart key with normal push button remote, factory alarm, factory immobilizer, etc.  I purchased a Clifford Matrix 50.5X and was planning on installing it onto this car.  My question is, is it possible to install this security system integrating it with the factory alarm system?  I want to be able to arm the factory alarm/immobilizer and the Clifford alarm with the Clifford Remote.
Is there anyone out there familiar with this system?  Or can anyone give me some guidance?
Any help will be appreciated
Thanx in advance,
SiC
Posted By: KPierson
Date Posted: November 13, 2007 at 9:39 AM
The car has only been out for a month, and isn't available in the USA yet, so chances are slim you'll find anyone with first hand experiance with this car.  I didn't even know Mitsu had a pushbutton start system!
Kevin Pierson
Posted By: sicbomb
Date Posted: November 13, 2007 at 3:35 PM
Yes, this is what I thought.  I was just hoping that there may be some people out there familiar with this system or anything similar.  The start system isn't a pushbutton type, it's actually a keyless switch.  You can also insert the key into that switch if the battery on your transmitter dies or if you lose the transmitter.
Posted By: stang351w
Date Posted: November 13, 2007 at 8:26 PM
i haven't installed anything on the push button starter ones, but i have done some things with a newer one.  seems to me you can do that, there just needs to be a arm and disarm wire from the alarm system that would connect to the arm and disarm wires of the mitsu, i'll check the computer at work tommrow and see if i can print off the wireing info for you.
Tri County KustomZ
certified installer
Posted By: sicbomb
Date Posted: November 13, 2007 at 11:51 PM
Thanks alotposted_image
In Japan the Mitsubishi Outlander, Galant, Eclipes, & Lancer all have the same type of system.  Maybe the same in North America too?
