keeping exterior lighting with new alarm?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=98951
Printed Date: April 17, 2026 at 5:17 PM
Topic: keeping exterior lighting with new alarm?
Posted By: carguy411
Subject: keeping exterior lighting with new alarm?
Date Posted: November 13, 2007 at 10:38 AM
i was wondering how you can keep the factory exterior lighting in the gm vehicles when you use an aftermarket alrm .
what im trying to do is when you use the original keyless entry and unlock the doors from the oem keyfob the headlights and reverse lights turn on , now is there anyway to do this and tap into the keyless system in the vehicle?
please let me know
thanks
Posted By: dswift
Date Posted: November 13, 2007 at 4:46 PM
use the Fortin Gmsl2. That should let you keep all the perimeter settings. I think... Pretty sure it will though.
------------- "dont ground out!"
Date Posted: November 20, 2007 at 11:33 AM
i think this is dicontinued . is there a new version of it? thanks
Posted By: KPierson
Date Posted: November 21, 2007 at 8:16 AM
You could hook up a time delay relay to the 'unlock' output of the alarm and set it for 20 seconds or so. Everytime you unlock the doors with the alarm remote the relay(s) will energize.
------------- Kevin Pierson
Posted By: howie ll
Date Posted: November 23, 2007 at 10:13 AM
Wouldn't it be simpler to use the light output from the alarm, then relay etc to the rev lights and headlights?
Posted By: enice
Date Posted: November 23, 2007 at 12:06 PM
Using the domelight supervision wire would be perfect for that. When you unlock the door it should give a 30sec time output and turn on the lights just the way you want it to. When you press the lock wire it will cancel the feature. Just make sure you diodle isolate them from each other.
Posted By: extreme1
Date Posted: November 23, 2007 at 3:00 PM
any data module for locks will retain the oem exterior lighting actions.
XK01
ADS-DL
etc.
------------- Shaughn Murley
Visions Electronics
Red Deer, Alberta
