Car won’t start at all -help-
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=9897
Printed Date: March 16, 2026 at 8:10 PM
Topic: Car won’t start at all -help-
Posted By: mytjoe
Subject: Car won’t start at all -help-
Date Posted: February 22, 2003 at 12:15 PM
I just installed a Viper 550 alarm/remote start. All functions of the alarm work properly except the remote start. My key dosen't even start the car. I didn't install the starter kill relay, so there isn't any interuption in the starter wire. Im stuck. Need my car so I can get to work tomorrow.
Posted By: BNLUIS
Date Posted: February 22, 2003 at 1:54 PM
what kind of car???? it will help.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
Posted By: mytjoe
Date Posted: February 22, 2003 at 4:15 PM
99 ford mustang. I got the car to start but the remote start still doesn't work. I checked the diagnostics and the led flashes 7 times, showing that there is a problem w/ the neutral safety shutdown. My wiring dia. of the car shows the starter wire and neutral safety switch beeing the same. Is this correct?
Posted By: Velocity Motors
Date Posted: February 22, 2003 at 4:33 PM
Two things : Is it a manual transmission & also did you bypass the PATS II system on the Mustang for it to start ?
Posted By: mytjoe
Date Posted: February 22, 2003 at 6:24 PM
It's an automatic trans. How do I bypass the PATS ll system? I didn't even know the car has one.
Posted By: auex
Date Posted: February 22, 2003 at 6:34 PM
The nuetral safety switch wire from the brain should go to ground in this vehicle. To bypass PATS you will need to purchase an immobilizer defeat, like DEI's 555f. You will need to place the pellet next to the ignition cylinder. Tip: To get the cylinder out put the key into the ignition turn the vehicle to run then look under the column and insert a small pick into the hole without a screw in it and pull the cylinder out gently.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: mytjoe
Date Posted: February 22, 2003 at 7:10 PM
Thanks for the help. I'll have to wait til tomorrow to get the part I need. I'll post again tomorrow and hopefully I'll be done!posted_image
Posted By: mytjoe
Date Posted: February 23, 2003 at 10:28 AM
Ok I am running out of time. This is what I have hooked up as of now,(Viper 550 remote start/alarm on 99 Ford Mustang. I have already bypassed Pats ll system.
12 Pin: RED / white to purple / YELLOW d.s. kick panel. Red to battery. Brown to +siren. Black grounded to chassis. Purple,Green,Blue,BLACK/ White,WHITE/ Blue are not hooked up. White to Brown at the light switch.Orange pre wired to starter kill relay.
Starter kill relay: Yellow to Grey / YELLOW at ignition.Green to Pink/white coming from ignition. Black to Pink/white going to starter. The Pink/white wire is cut in half.
6 pin: BLACK/ white to chassis ground.Violet/white to tachometer at p.s. kick panel. Gray to hood pin switch.Brown to RED / green at brake switch.Blue and Blue/black not hooked up.
Satellite Relay: 2 Red to L.GREEN/ purple at ignition. Pink to RED / green at ignition. Orange to Gray / YELLOW at ignition.Purple to WHITE/ pink at ignition. Pink/white to RED / black at ignition.
Please HELP me figure out why the remote start won't activate.
Posted By: Chris Luongo
Date Posted: February 23, 2003 at 10:53 AM
Okay, a few more questions. You say the car won't start, even with the key?
Most (but not all) of your wiring looks to be correct. But I've never done a newer Mustang; I'm just going from a tech sheet here...the sheet could always be wrong too.
The trunk release is high-current positive trigger; the DEI's RED / white is a low-current negative trigger---you'll need to use a relay-----but doing this wrong shouldn't affect your remote starter at all.
What happens when you try to start the car with the key? Do the radio, heater, seat belt buzzer, warning lights...do they still work? Is the red THEFT or SECURITY light flashing rapidly, or did it come on and then go out as usual?
If the heater and stuff doesn't work, you may have blown a fuse during your install...this happens to all of us once in a while. Go back to the column and test all the yellow and light GREEN/ purple wires...do they still have power? Then, go check the set of large fuses under the hood. From then on, lay some duct tape on those metal bars near the ignition wires---this will keep you from blowing fuses again.
While you're at it, check the fuses going to the remote starter and its relay pack---although even if these fuses were blown, you'd still be able to start the car with the key.
Or, if the THEFT light is flashing....it's time to revisit your PATS bypass. How did you do it? You mentioned that the blue and blue/black from the remote starter are not connected to anything.....these are typically used to power up the DEI 555F or DEI 555U PATS interfaces.....so leaving these unconnected makes me think you've made a wiring error, or you're making your own PATS bypass.
If you've decided to remove the PATS pellet from one of your keys and glue it to the key cylinder...remember that you might have to empty out all your other keys as well-----some cars won't start if they "see" two pellets at the same time.
And remember another troubleshooting trick. You can take away EVERYTHING you've done to bypass PATS. Then, the car should (hopefully) start using the key. After that, the remote start will work perfectly, as long as you leave a good key in the ignition------continue like this until you get everything else working right, then worry about PATS last.
Posted By: mytjoe
Date Posted: February 23, 2003 at 1:11 PM
I got the remote start to engage but the starter stays engaged too. I can't seem to figure out how to program the alarm to detect the tachometer/voltage. I think it's programmed to start w/out checking voltage/tachometer. It will start, the starter stays engaged, then a few seconds later the car shuts down, a few seconds after that it starts this cycle over again and the car will start ect. ect.
Posted By: BNLUIS
Date Posted: February 23, 2003 at 4:38 PM
First of all you probablly have the wrong tach wire or is not programmed , You said you connect it on the passangers kick panel?????? Get the right tach wire and programm it this way.
1-- start car with key
2-- within 5 second after car starts press and hold Valet switch
3-- alarm light will come on solid, let go af Valet switch and parking lights will be now you Tach wire is programmed
  TACHOMETER|*2                  |   |*2
*2 3.8 liter find coil pack at top front of engine. Use tan/white, tan/orange or tan/light green. 4.6 liter SOHC and 4.6 liter DOHC, two coils at top front of engine. Use RED / yellow, pink/white, RED / light blue or dark blue/light blue.
Good luck
Luis
Sound Waves
Posted By: mytgijoe
Date Posted: February 23, 2003 at 8:14 PM
Thanks to everyone that helped. Everything works great! Thanks,  Mytjoe
