2002 hyundai accent door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99006
Printed Date: May 15, 2026 at 2:27 PM
Topic: 2002 hyundai accent door locks
Posted By: window
Subject: 2002 hyundai accent door locks
Date Posted: November 14, 2007 at 3:49 PM
wire diagram says add accuator nerver done this before can someone help by the way the locks are power if i lock from driver side but no swicth in car
Posted By: KarTuneMan
Date Posted: November 14, 2007 at 4:37 PM
The reason you need to add the acctuator is because there is no switch. if you lock the door's then reach in and use the unlock latch on the drivers doo.....all the doors unlock. SO, inside the drivers door you need a motor to flip that latch (the actuator) when the actuator is triggered it will move the latch, unlocking your doors.
2 relays, the installed actuator.....and you now have keyless entry. Wire your relays like so. (unless the unit you are installing has them built in...
posted_image
Posted By: window
Date Posted: November 16, 2007 at 9:01 PM
are they hard to install inside the and is it a certain place where you mount it
