2003 ranger, alarm/keyless entry
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99095
Printed Date: April 24, 2026 at 5:36 AM
Topic: 2003 ranger, alarm/keyless entry
Posted By: dennis rider
Subject: 2003 ranger, alarm/keyless entry
Date Posted: November 17, 2007 at 12:30 PM
hello,
i have a 2003 ranger that i am trying to install a crimestopper rke 865 ll keyless entry...i am having trouble with the doors unlocking can you help...also a wiring for alarm
pvd41
Posted By: timechange2007
Date Posted: November 17, 2007 at 12:37 PM
Door locks going into sleep mode. not sure how to help you on this sorry.
Posted By: KarTuneMan
Date Posted: November 17, 2007 at 1:10 PM
Explain what it is that is not functioning properly.
What do you need help with? I see you said you are having "trouble"   What kind of trouble?
LOCK Pink / YELLOW In driver's kickpanel   -
 On base model, the doorlocks are reverse polarity with same color wires.
 UNLOCK Pink/lt.green In driver's kickpanel   -
FACTORY DISARM Dk.GREEN/ purple In driver's kickpanel   -
I have never known a ranger to have a BCM that goes to sleep. You can "wake it up" with the disarm wire.....if it's there. OR pulse the door pin.
Date Posted: November 18, 2007 at 12:10 PM
i have a 2003 ranger that i am putting a crimestopper rke865 ll on and i need to know where the lock/unlock wires are...also how to bypass the gem from the factory ke
pvd41
Date Posted: November 18, 2007 at 3:53 PM
See my post above....posted_image
