push button start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99110
Printed Date: April 23, 2026 at 5:17 PM
Topic: push button start
Posted By: residentg33k
Subject: push button start
Date Posted: November 17, 2007 at 7:32 PM
Vehicle: 1997 Nissan Sentra GXE
Switches: 3 Switches, two regular SPDT Flip Switches and one Monetary Switch.
My question is, how easy would it be to install a push button start into my car instead of using the standard key ignition? I'm pretty familiar with Electronics as well as Car Electronics but I just need to be pushed in the correct direction.
The two switches will be used to power on my accessories and Fuel Pump and what not. The third switch will be used to start the car. I can shut off the vehicle by turning off the two switches which will act like Turning the Ignition off.
Posted By: offroadzj
Date Posted: November 18, 2007 at 7:11 PM
Just make sure you activate all of your ignitions as well as all of your accessories. Also make sure that you use relays so you dont have too much draw on the switches themselves. You will then just need to find a way to unlock your steering wheel and shifter lock.
------------- Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
