07 sebring sedan, what bypass?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99115
Printed Date: April 23, 2026 at 3:37 PM
Topic: 07 sebring sedan, what bypass?
Posted By: todds440
Subject: 07 sebring sedan, what bypass?
Date Posted: November 18, 2007 at 7:27 AM
Who's done a remote starter on a 07 Chrysler Sebring sedan? What bypass did you use? Any big hurdles or troubles that I should know about ahead of time? I know newer Chrysler products can be a real treat! Any one have wiring diagrams? Thanks
Posted By: tedmond
Date Posted: November 18, 2007 at 7:39 AM
this car does have a transponder, u need a bypass kit to do so, and a few resistors for lock, unlock accessory and start. I think idatalinks are the best for ur application. one data bus wire should control all the things u need. less wires to cut.
Posted By: Chris Luongo
Date Posted: November 18, 2007 at 9:25 AM
Those cars are pretty easy.
All you need at the steering column is one ignition, and there's a low-current negative starter wire.
No point in hooking up locks, since the customer will be carrying the factory remote anyway.
The least expensive bypass would be a blank Chrysler key and a universal bypass box........ you could use a DEI 556C or the equivalent from bypasskit.com, but I'm pretty sure that's more expensive.
Posted By: todds440
Date Posted: November 18, 2007 at 12:51 PM
This isnt another Chrysler product that will only disarm the alarm with the factory remote? Alarm R/S wont disarm factory alarm?
