04 pontiac aztek
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99275
Printed Date: May 15, 2026 at 11:32 PM
Topic: 04 pontiac aztek
Posted By: anthonylecuona
Subject: 04 pontiac aztek
Date Posted: November 23, 2007 at 3:25 PM
using a 5ooors scytek alarm the vehicle shows three ignition circuits but the alarm remote start only has two. does the third need to be hooked up? and if so can i just use a relay and run from the second ignition output and connect it to ign.2 and 3 together?
------------- In case of snow drive backwards, instant front wheel drive, then again who needs it when you drive a Scoobie
Posted By: KarTuneMan
Date Posted: November 23, 2007 at 4:38 PM
| 12 VOLTS | Orange | Ignition switch harness | + | | | | This wire should not be used to power a remote starter. You can run a line to the battery, or you can find power at the relays in the center console by removing the plastic side panel on the driver's side of the console. See the photo. |
| | IGNITION | Pink | Ignition switch harness | + | | IGNITION 2 | Dk.green | Ignition switch harness | + | | ACCESSORY | Orange | Ignition switch harness | + | | STARTER | Yellow | Ignition switch harness | + | | KEY SENSE | Lt.green | Pin-A1 on C0 connector at BCM | - | | | | The Body Control Module is locate behind the center console. Remove the plastic panel on the driver's side of the console to access. See the BCM diagram for exact pin locations. |
Posted By: techman93
Date Posted: November 25, 2007 at 2:42 PM
You can run a relay to the other ignition you need to power up by hooking up a negative output off remote start that is a 2nd ignition out put.
Battery MUST RUN WIRE TO BATTERY
Ignition 1 PINK (+) IGNITION SWITCH HARNESS
Ignition 2 DARK GREEN (+) IGNITION SWITCH HARNESS
Accessory 1 BROWN (must be powered) (+) IGNITION SWITCH HARNESS
Accessory 2 ORANGE (+) IGNITION SWITCH HARNESS
Starter 1 YELLOW (+) IGNITION SWITCH HARNESS
pin 85 to 12v+ fused
pin 86 to (-) 2nd ignition
pin 30 to 12v+ fused
pin 87 to 2nd ignition wire in vehicle
You may have to find a second accessory as well unless the 2nd accessory is only to power radio and wiper circuit.
------------- The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
Date Posted: November 25, 2007 at 11:58 PM
thanks guys will reply when i hook it up this weekend.
