remote start on manual, 07 jeep wrangler
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99380
Printed Date: May 15, 2026 at 7:23 PM
Topic: remote start on manual, 07 jeep wrangler
Posted By: pacojeep
Subject: remote start on manual, 07 jeep wrangler
Date Posted: November 26, 2007 at 6:19 PM
Hi I'm going to install a scytek galaxy 5000RS-2W for manual transmission on my Jeep Wrangler JK 07 and have a little question about clutch bypass
In the install manual ()https://scytek.net/pdf/product_galaxy_combo_5000RS-2W_manual.pdf , it says to connect the ground when runing output with a clutch bypass relay
Here is the 2 type of relay
posted_image
Here is my vehicule clutch and starter wiring diagram and the clutch switch connector:
posted_image
posted_image
posted_image
So the clutch interlock wire is yellow/orange but I'm really not certain of which of these relay to use
thx marco
Posted By: KarTuneMan
Date Posted: November 27, 2007 at 2:29 AM
The Astrochart shown using the yellow/orange on the switch . A negative start signal.
It can also be found at the PCM C3 white connector pin 21 white wire. same negative start signal.
Posted By: pacojeep
Date Posted: November 27, 2007 at 8:46 AM
I know which wire to use ... I don't know whitch relay to use ...
Posted By: moonliter
Date Posted: November 27, 2007 at 10:36 AM
If your rs has no neg start wire, then just use relay 1. connect pin 30 to black (cav2) and pin 87 to yellow/orange (cav3) wire.
Posted By: pacojeep
Date Posted: November 27, 2007 at 5:04 PM
Heu .... black is cav3 and yellow/orange is cav2 and(-)
Date Posted: November 27, 2007 at 8:10 PM
Oops, you are right. I got the cav 2 & cav 3 mixed up, anyway it could have done no harm.
