2004 hyundai accent transponder
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99453
Printed Date: May 15, 2026 at 10:06 AM
Topic: 2004 hyundai accent transponder
Posted By: Slamminsubz
Subject: 2004 hyundai accent transponder
Date Posted: November 28, 2007 at 6:58 PM
For some reason my password on DirectTechs isn't working anymore. Does anyone have any idea if an 04 Accent has a transponder? Also a wiring diagram would be helpful. Thanks.
Posted By: another-kelly
Date Posted: November 28, 2007 at 7:31 PM
          Security
     WIRE          COLOR          POLARITY          LOCATION
     Battery          BLACK/ BLUE OR RED          (+)          IGNITION SWITCH HARNESS
     Ignition 1          BLACK/ WHITE OR GREEN          (+)          IGNITION SWITCH HARNESS
     Starter 1          BLACK / YELLOW OR WHITE          (+)          IGNITION SWITCH HARNESS
     All Door Trigger          GREEN          (-)          DRIVERS KICK PANEL
     Trunk Trigger          GREEN/ ORANGE          (-)          IN HARNESS IN DRIVERS KICKPANEL
     Parking Lights          DARK GREEN/ BLACK          (+)          IN HARNESS IN DRIVERS KICKPANEL
     Convenience
     Headlights-Lo          BLUE/BLACK          (-)          AT LIGHT SWITCH HARNESS.
     Remote Start
     Accessory 1          BLUE/RED OR YELLOW          (+)          IGNITION SWITCH HARNESS
     Key Sense          RED / BLACK          (+)          CHIME MODULE TO THE RIGHT OF STEERING COLUMN
     Tachometer          BROWN / YELLOW OR BROWN / RED          (AC)          AT IGNITION COIL
     Speed Sense          BLUE/BLACK          (AC)          AT DIAGNOSTIC CONNECTOR BELOW STEERING COLUMN
               4000 PPM
     Brake Lights          GREEN          (+)          AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights          PURPLE          (+)          LARGE HARNESS IN DRIVERS KICK PANEL
     Horn          BLACK/ WHITE          (-)          AT STEERING COLUMN HARNESS
     Modules
     WIRE          LOCATION
     Please select another category
     Doorlocks/Windows
     Power Unlock          ADD ACTUATOR          (AC)          AT KEYLESS ENTRY MODULE TO LEFT OF STEERING COLUMN
               VEHICLES WITHOUT OEM KEYLESS ENTRY REQUIRE ACTUATORS TO OPERATE DOOR LOCKS.
     Power Lock          ADD ACTUATOR          (AC)          AT KEYLESS ENTRY MODULE TO LEFT OF STEERING COLUMN
and as for a bypass required, do believe only hyundai's sold in canada required one
Date Posted: November 28, 2007 at 10:14 PM
thanks, i told her i might need an extra key and i have a 556uw lying around if i need it.
Posted By: extreme1
Date Posted: November 28, 2007 at 11:45 PM
no accents had transpnder that I've ever done.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Posted By: Twelvoltz
Date Posted: November 29, 2007 at 7:40 AM
x2 on never seeing a US Hyundai Accent with a transponder
Posted By: mobile1
Date Posted: November 29, 2007 at 12:21 PM
hyundais and Kias only have transponders when the vehicle is made in Canada. Korean models do not have them. Just look at the "manufactured in" sticker in the door jam.
Date Posted: December 01, 2007 at 10:05 AM
alright the car is made in korea, so i guess no transponder. Another couple quick questions. I had another diagram that said that there were 2 parking light + wires and i needed a relay, is that true? Also, that diagram says the car has 2 acc. wires one yellow and and extra one that is blue. Lastly, anyone have the colors for the power door locks. The diagrams just say to add actuators if it doesnt have keyless, but it does. Thanks
Posted By: perly
Date Posted: December 01, 2007 at 12:40 PM
your car probably has central door locks which means that you need to add an actuator in the drivers door in order to make them work with the aftermarket equip. I know it seems like you have power door locks because when you turn the key in the ignition your doors lock but more then likely you do not. I know that every Hyundai I have worked on has had the central locking systems. It is kind of hard to explain but just know that 9 out of 10 times on Hyundai cars you need to add actuators.
Posted By: techman93
Date Posted: December 01, 2007 at 7:31 PM
I have had to install a couple times an actuator in drivers door only. It is a pain but you should be able to charge a tad extra for the work.
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
