duramax remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99466
Printed Date: May 15, 2026 at 5:12 AM
Topic: duramax remote start
Posted By: kaczarcollision
Subject: duramax remote start
Date Posted: November 29, 2007 at 12:11 AM
first off i know what i am going to ask is shunned upon. but it is my personal truck and i am willing to take full responsiblity. i just installed a shelby 750r into my 02 duramax silverado. works fine with me manually depressing the clutch. last thing to do is bypass the clutch switch. or atleast what to make of the wires i tested and how to figure it out on my own. any help would be greatly appreciated.
------------- disturbing the peace since 1984
Date Posted: November 29, 2007 at 9:37 AM
nobody wants to help??
Posted By: Twelvoltz
Date Posted: November 29, 2007 at 9:44 AM
No one will help because what you are doing is a safety hazard. Installing a remote start in a manual transmission vehicle that is designed for an automatic not only puts you in jeopardy of property damage, but what happens when your truck lunges forward and hits a pedestrian or a child...then the liability extends far beyond just financial responsibility.
Pick up a DEI 689M and do the job correctly.
------------- Installer, IT support, and FFL. I need less hobbies.
Posted By: KarTuneMan
If the unit you installed is NOT designed for a manul transmission.....no one will help you. Against forum rules. If you continue to ask, the thread will be locked, so I would stop.
Date Posted: November 29, 2007 at 4:53 PM
i totally understand where you guys are coming from. i appreciate your time. i just figured someone could point me in a direction because i've searched on here and found diagrams for other cars. but i appreciate your time
Date Posted: November 29, 2007 at 10:48 PM
and thanks to twelvotz for recommending the dei piece. i didn't know such a piece was available.
