2007 kia sorento remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99474
Printed Date: May 15, 2026 at 12:08 AM
Topic: 2007 kia sorento remote start
Posted By: airadam
Subject: 2007 kia sorento remote start
Date Posted: November 29, 2007 at 9:56 AM
Does anyone have a wiring diagram for a 2007 KIA Sorento LX
Posted By: Twelvoltz
Date Posted: November 29, 2007 at 10:06 AM
Audiovox Lists:
          #512093: 2007 KIA SORENTO 4DR SUV WITH 3.3L ENGINE AND PREMIUM AUDIO SYSTEM
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Battery          GREEN          (+)          CONNECTOR "B" (14 PIN CONNECTOR)
     Accesory          GREEN /ORANGE          (+)          CONNECTOR "B" (14 PIN CONNECTOR)
     Ground          BLACK          (-)          CONNECTOR "B" (14 PIN CONNECTOR)
     Illumination          RED / BLUE          (+)          CONNECTOR "B" (14 PIN CONNECTOR)
     Dimmer          YELLOW          (-)          CONNECTOR "B" (14 PIN CONNECTOR)
     LF Speaker (+)          TWEETER IS BLUE (+)/ MIDRANGE IS BLACK (+)/ SUB IS YELLOW (+)
     LF Speaker (-)          TWEETER IS BROWN / RED (-)/ MIDRANGE IS WHITE (-)/ SUB IS BLUE (-)
     RF Speaker (+)          TWEETER IS BLUE/ORANGE (+)/ MIDRANGE IS BLACK (+)/ SUB IS BLACK (+)
     RF Speaker (-)          TWEETER IS GREEN/ ORANGE (-)/ MIDRANGE IS BROWN RED (-)/ SUB IS WHITE (-)
               THE FRONT SUB AND MIDRANGE'S MAY HAVE AN AMPLIFIER BUILT INTO THEM.
     LR Speaker (+)          BLUE
     LR Speaker (-)          GREEN
     RR Speaker (+)          YELLOW
     RR Speaker (-)          BLUE
     Amp Location          IF EQUIPPED, UNDER DRIVERS SEAT
Security
     Battery          GREEN (40 AMP) BLUE (30 AMP)          (+)          AT IGNITION SWITCH PINS 2 & 5
     Ignition 1          YELLOW          (+)          AT IGNITION SWITCH PIN# 6
     Starter 1          RED          (+)          AT IGNITION SWITCH PIN# 1
     All Door Trigger          BLUE          (-)          IN DRIVERS A PILLAR OR 22 PIN PLUG ON RIGHT AT BCM PIN# 22
               MAY ALSO BE A RED / BLACK IN DRIVERS A PILAR. THERE ARE 3 RED / BLACK WIRES MUST TEST TO OBTAIN THE CORRECT WIRE. TEST WITH DRIVERS DOOR LATCHED.
     Domelight Super          SAME AS ALL DOOR TRIGGER          (-)          USE RELAY WITH LOW CURRENT DOME LAMP OUTPUTS
     LF Latch          BLUE          (-)          AT SWITCH IN DOOR JAMB OR PIN# 11 IN LEFT PLUG ON BCM
               ALL LATCH WIRES ARE IN DRIVERS KICK
     RF Latch          GREEN/ BLACK          (-)          AT SWITCH IN DOOR JAMB OR PIN# 12 IN LEFT PLUG ON BCM
     LR Latch          BLUE/BLACK          (-)          AT SWITCH IN DOOR JAMB OR PIN# 24 IN LEFT PLUG ON BCM
     RR Latch          BLUE/BLACK          (-)          AT SWITCH IN DOOR JAMB OR PIN# 24 IN LEFT PLUG ON BCM
     Trunk Trigger          GREEN          (-)          DRIVERS KICK
     Parking Lights          YELLOW\BLACK          (+)          LOWER DRIVERS KICK
     Low Crr Pk Lights          WHITE          (-)          AT LIGHT SWITCH OR BCM PIN# 4 IN A 16 PIN PLUG (PLUG IN MIDDLE)
     Convenience
     Headlights-Lo          ORANGE          (+)          UNDER HOOD AT E/R/J/B
     Headlights-Hi          YELLOW          (+)          UNDER HOOD AT E/R/J/B
     Parking Brake          RED          (-)          AT SWITCH BETWEEN SEATS OR IN DRIVERS KICK
     Trnk Release          RED / ORANGE          (-)          THIS WIRE WILL RELEASE THE GLASS
               THIS WILL RELEASE THE GLASS ONLY.
Remote Start
     Accessory 1          WHITE          (+)          AT IGNITION SWITCH PIN# 4
     Accessory 2          ORANGE
     Anti-Theft Type          TRANSPONDER IN KEY (NOT ALL SORENTOS WILL HAVE THE TRANSPONDER. IF YOUR VEHICLE DOES THERE WILL BE A RING AROUND KEY WITH A YELLOW AND BLUE WIRE COMING FROM IT
     Anti-Theft Descript          RF ACTVATED
     Key Sense          YELLOW/ORANGE          (+)          NEXT TO IGNITION SWITCH PLUG OR LEFT PLUG AT BCM PIN# 16
     Tachometer          WHITE          (AC)          ECM PIN# 61 (CORNER PIN NEXT TO A BLUE).
               CAN ALSO BE FOUND IN PASSENGER KICK IN A MIDDLE PLUG AS GREEN/ BLACK
     Speed Sense          GREEN          (AC)          AT ECM PIN# 52(CLOSER TO MIDDLE OF PLUG BETWEEN A GREEN AND BLACK WIRE) OR ISTRUMENT CLUSTER PIN# 15
               INSTRUMENT CLUSTER CONNECTOR IS THE MIDDLE 20 PIN PLUG. OR BROWN WIRE AT BCM PIN# 6 IN LEFT CONNECTOR
     Low Crr. Pk Lights          WHITE          (-)          AT LIGHT SWITCH OR BCM PIN# 4 IN A 16 PIN PLUG (PLUG IN MIDDLE)
     Brake Lights          WHITE          (+)          AT BRAKE SWITCH OR DRIVERS SILL PLATE
     Reverse Lights          BLUE/BLACK          (+)          IN PLUG ON PASSENGER SIDE OF CONSOLE ABOUT 4 INCHES ABOVE THE CARPET LINE.
               WIRE RUNS DOWN THE DRIVERS SILL PLATE.
     Horn          BLUE/BLACK          (-)          AT CLOCK SPRING CONNECTOR OR 22 PIN CONNECTOR AT BCM PIN #10
               RIGHT SIDE CONNECTOR
Modules
     WIRE          LOCATION
     Module 1          BCM IS MOUNTED VERTICALLY WITH THE PLUGS FACING DOWN BEHIND THE HEATER/AC CONTROLS
     Module 2          I/P/J/B (INSTRUMENT PANEL JUNCTION BOX) LOCATED IN THE DRIVERS SIDE KICK (IT IS THE FUSE BOX)
     Module 3          ECM (ENGINE CONTROL MODULE) LOCATED UNDERHOOD CLOSER TO FIREWALL ON PASSENGER FENDERWELL
     Module 4          I/C MODULE (INSTRUMENT CLUSTER MODULE) LOCATED ABOVE THE I/P/J/B
     Module 5          E/R/J/B (E/R JUNCTION BOX) LOCATED UNDER HOOD (FRONT PASSENGER SIDE)
     Doorlocks/Windows
     Door Lock Circuit          3 WIRE NEGATIVE
     Power Unlock          WHITE/ SILVER DOTS          (-)          DRIVER DOOR HARNESS ABOVE FUSE BOX
     PowerLock          BLUE\LT BLUE          (-)          DRIVER DOOR HARNESS ABOVE FUSE BOX
     Driver Mtr Unlock          WHITE          (REV)          IN DRIVERS KICK
     Driver Mtr Lock          RED          (REV)          IN DRIVERS KICK
     Pas Mtr Unlock          WHITE          (REV)          IN DRIVERS KICK
     LF Window Up          BLUE          (REV)          AT DRIVERS DOOR WINDOW SWITCH
     LF Window Dn          GREEN          (REV)          AT DRIVERS DOOR WINDOW SWITCH
     RF Window Up          ORANGE          (REV)          DRIVERS KICK
     RF Window Dn          RED          (REV)          DRIVERS KICK
     LR Window Up          YELLOW          (REV)          BOTTOM PLUG IN DRIVERS KICK
     LR Window Dn          WHITE          (REV)          BOTTOM PLUG IN DRIVERS KICK
     RR Window Up          YELLOW          (REV)          DRIVERS KICK
     RR Window Dn          WHITE          (REV)          DRIVERS KICK
Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
