fortins gm sl2 wont work in trucks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99478
Printed Date: May 14, 2026 at 9:29 PM
Topic: fortins gm sl2 wont work in trucks
Posted By: NismaX
Subject: fortins gm sl2 wont work in trucks
Date Posted: November 29, 2007 at 11:55 AM
I got this from Fortin themselves. I had some issues with this module that I'd like to pass on. They say it won't work and has been discontinued use the GM-SL (if you can find one) or a INT-SL which is new. This is just fantastic news to come upon when your customer wonders why you are having problems with an install that should be pretty text book by now. By the way the install was in an '04 Suburban.
Jon
Traveling Electronics
Posted By: johnmax
Date Posted: November 29, 2007 at 11:56 AM
Done tons of those in full size trucks. Once they figured out the battery draw issue, no further problems. Must have a couple hundred out there. They worked on all those.
Posted By: tedmond
Date Posted: November 29, 2007 at 2:53 PM
most problems with the Fortin units were the battery issue as johnmax mentioned. Mostly on hondas when not enough power was avail for car to start, the ECU reset a few times and it wouldnt allow car to start. But after the latest firmware, all should be fixed. Im sure the GM sl2 should work. Maybe it jsut needs the newest firmware. Download the new one if u got the flash link updater.
Posted By: saskpuller
Date Posted: November 29, 2007 at 5:00 PM
Do you have any versions or serial numbers that these are causing problems on? I just got in 25 of these for the GM trucks and had planned on using them next week. Are these updateable? Might need to rethink this.
Posted By: tedmond
Date Posted: November 29, 2007 at 5:43 PM
they are updatable if u haev the flash link connecter, as far as version, check on Fortin website. www.ifar.ca
Posted By: todds440
Date Posted: November 29, 2007 at 5:50 PM
Just curious, what type of problem were you having? Passlock starting problems, doorlock problems, etc.?
Posted By: dre187
Date Posted: November 29, 2007 at 8:58 PM
Usually it was battery brain problems with the GMSL2. The BCM of the vehicle would "go to sleep" after the car has been shut off and had no actions for a certain lengh of time (i don't remember how long). This reduces the current draw on the battery. basically the GMSL2 wouldn't let the bcm go to sleep and would drain the battery. it was very intermittant too, really irritating until they figured the problem. there is upgradeable firware now anyways so its no big deal anymore.
Date Posted: November 29, 2007 at 11:51 PM
So the newest upgrade fixes the problem. That would be cool. Don't need anymore problems this week. can anyone tell me if these will turn on the heated seats and mirrors on chevy trucks? The manual says so but I was looking for actual user confirmation. And if so, how does the bypass know what the engine temp is? Is that a data thing?
Date Posted: November 29, 2007 at 11:59 PM
Just went to www.ifar.ca . I can't seem to see where the gm-sl2 is an upgradeable unit. I see that the can-sl2 is but that is it. Someone please enlighten me on this. I'm thinking I'll call fortin on Friday to make sure. Does anyone have a name in tech support that mentioned this whole subject.
Posted By: tedmond
Date Posted: November 30, 2007 at 2:14 PM
check this out bro. https://bypasskits.fortinautoradio.com/en/products/kits_coming_soon/gm-sl2/from what i see the latest firmware i see is Version 1.8
Posted By: NismaX
Date Posted: November 30, 2007 at 6:09 PM
If you go on Fortin's site the GM-SL2 has been discontinued. The replacement is the INT-SL. I don't think the module is the programmable type anyway. The version I have is 1.9
The problem was that if you left the door open for a couple of minutes the door locks would cycle once and the module LED would come on. At that point the car wouldn't start. I discovered anytime the LED was on the car wouldn't start. Randomly the car would start but set the factory alarm off. Very unreliable operation. I wanted to just use the DEI 457GW that I have had luck with before but it's gone too.
Good luck!
Jon Mason
Posted By: dre187
Date Posted: November 30, 2007 at 8:48 PM
you unfortunately had to send the unit in to be updated. this was available wen the gmsl2 was first out and the problem first arrived. i havnt used it in a while but if you need to use it, call fortin and they should do it for you. As far as the heated seats go, i never got to see them work since i tested the vehicle in a warm shop just after the install. its SUPPOSED to work through data bus, but never got any feedback if it actually did or not. Most newer GM trucks have temperature sensors, the disply for it is usally in the rear-view mirror.
Posted By: tedmond
Date Posted: November 30, 2007 at 10:43 PM
i dont think the heated seats ever work through data. Usually a pulse or latched signal is used to turn on heated seats. The data modules are nice to have, but the outputs on them are crappy eg Tach. sometimes it dont even work. Run tach straight to engine coil.
Date Posted: December 03, 2007 at 12:05 PM
i just checked my stock. They are all Version 1.9. Can anyone tell me if I will have issues with these on chev trucks, trailblazers, yukons tahoes etc. I don't have enuf time to be fixing after the fact.
Posted By: NismaX
Date Posted: December 05, 2007 at 7:27 AM
Hi
For what I was told all Chevy trucks have issues with this bypass. And by the way it wasn't a bad bypass since I had two and they both did the same thing. The tech told me that they work fine in cars.
Jon
