| Print Page | Close Window |
alarm/start on a 06 chevy express vanPrinted From: the12volt.comForum Name: Car Security and Convenience Forum Discription: Car Alarms, Keyless Entries, Remote Starters, Immobilizer Bypasses, Sensors, Door Locks, Window Modules, Heated Mirrors, Heated Seats, etc. URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99539 Printed Date: May 14, 2026 at 10:45 AM Topic: alarm/start on a 06 chevy express van Posted By: turboawd Subject: alarm/start on a 06 chevy express van Date Posted: December 01, 2007 at 1:29 AM its been a while since i put an alarm in. anyways, i was wanting to put an alarm(2way)/remote start in my 06 chevy express cargo van diesel. i currently have factory remote locks. i've seen a few van diagrams on this site, with some variences. is there an up to date wiring diagram, with the necessary wires for the diesel? also, any good recommendation for a remote/alarm unit? i'd like to have the 2way for keeping at home(use to start only,and notification), and to have a normal sized fob for most times. also, i'd need a unit compatible with a diesel. thanks Replies: Posted By: Twelvoltz Date Posted: December 01, 2007 at 6:53 AM Audiovox Lists:
#509458: 2006 CHEVROLET VAN VAN Audio/Mobile Video WIRE COLOR POLARITY LOCATION Battery ORANGE (+) RADIO HARNESS Accesory YELLOW (+) RADIO HARNESS THIS WIRE IS A CLASS-2 DATA WIRE - DO NOT USE AS AN ACCESSORY TURN-ON. Ground BLACK/ WHITE (-) RADIO HARNESS Dimmer GRAY (+) RADIO HARNESS LF Speaker (+) DARK BLUE LF Speaker (-) LIGHT BLUE RF Speaker (+) ORANGE RF Speaker (-) DARK GREEN LR Speaker (+) TAN LR Speaker (-) WHITE RR Speaker (+) TAN RR Speaker (-) ORANGE Steering Cntrls NO THIS VEHICLE MAY BE EQUIPPED WITH OPTIONAL ONSTAR® TELEMATICS EQUIPMENT. USE AN APPROPRIATE INTEGRATION HARNESS OR INSTALLATION PROCEDURE TO ENSURE PROPER FUNCTION OF THIS EQUIPMENT. Speed Cntrl OPTIONAL Radio Security YES Security WIRE COLOR POLARITY LOCATION Battery RED (+) IGNITION SWITCH HARNESS Ignition 1 PINK (+) IGNITION SWITCH HARNESS Starter 1 YELLOW (+) IGNITION SWITCH HARNESS All Door Trigger VIOLET (-) IN HARNESS IN PASSENGER KICKPANEL Domelight Super GRAY/BLACK (+) BCM BLACK PLUG PIN E LF Latch TAN (-) BLUE PLUG AT BCM OR 16 PIN PLUG IN DR. KICK RF Latch LIGHT GREEN (-) BLUE PLUG AT BCM OR 16 PIN PLUG IN DR. KICK RR Latch YELLOW/BLACK (-) BLUE PLUG AT BCM OR 16 PIN PLUG IN DR. KICK THIS COVERS THE SIDE DOOR ONLY Trunk Trigger LIGHT GREEN (-) BLUE PLUG AT BCM OR 16 PIN PLUG IN DR. KICK SHARED WITH PASSENGERS FRONT DOOR. TEST ACCORDINGLY. Parking Lights BROWN (+) FUSEBOX UNDER SEAT Low Crr Pk Lights BROWN / WHITE (-) AT MASTER SWITCH THERE ARE TWO USE ONLY NEG. Convenience WIRE COLOR POLARITY LOCATION Headlights-Lo WHITE (-) BCM, LT.BLUE PLUG PIN A12 Wipers-Lo PINK (-) WIPER SWITCH Wipers-Hi DARK BLUE (-) WIPER SWITCH Remote Start WIRE COLOR POLARITY LOCATION Battery RED (+) IGNITION SWITCH HARNESS Ignition 1 PINK (+) IGNITION SWITCH HARNESS Ignition 2 WHITE (+) IGNITION SWITCH HARNESS Accessory 1 ORANGE (+) IGNITION SWITCH HARNESS Accessory 2 BROWN (+) IGNITION SWITCH HARNESS Starter 1 YELLOW (+) IGNITION SWITCH HARNESS Anti-Theft Type PASSLOCK II Anti-Theft Descript A RESISTANCE BASED SYSTEM THE PASSLOCK 2 WIRE COLORS ARE YELLOW, TAN, AND ORANGE / WHITE (NOT USED). Key Sense LIGHT GREEN (-) IGNITION SWITCH HARNESS Tachometer TAN OR YELLOW/BLACK (AC) PCM UNDER HOOD BLUE PLUG PIN 36 OR 37 FOR CRUISE CONTROL APPLICATION, GROUND BLUE TACH WIRE ON CRUISE SERVO Speed Sense GREEN / WHITE (AC) PIN 50 @ PCM IN A GREEN CONNECTOR CRUISE CONTROL - 250-1316 CRUISE SERVO & 250-3421 CRUISE LEVER VSS - DRIVERS FENDERWELL. GREEN CONNECTOR, PIN #50 IS A GREEN / WHITE WIRE AT 4000 PPMS Parking Lights BROWN (+) FUSEBOX UNDER SEAT Low Crr. Pk Lights BROWN / WHITE (-) AT MASTER SWITCH THERE ARE TWO USE ONLY NEG. Brake Lights WHITE (+) BRAKE SWITCH Reverse Lights LT. GREEN (+) BCM,BLACK PLUG PIN F Horn TAN (-) STEERING COLUMN HARNESS Modules WIRE LOCATION Module 1 PASSLOCK - YELLOW AND TAN Module 2 ECM - ENGINE CONTROL MODULE LOCATED BELOW GLOVE BOX AREA Module 3 PCM - POWERTRAIN CONTROL MODULE IS LOCATED DRIVER'S FRONT ENGINE COMPARTMENT Module 4 BCM-LOCATED ON PASSENGER SIDE BEHIND THE KNEE BOLSTER Doorlocks/Windows WIRE COLOR POLARITY LOCATION Power Unlock WHITE (-) BCM LT. BLUE PLUG PIN B10 PowerLock BLUE (-) BCM LT.BLUE PLUG PIN B5 Driver Mtr Unlock TAN (REV) DRIVER'S KICK PANEL Driver Mtr Lock GRAY (REV) DRIVER'S KICK PANEL Pas Mtr Unlock TAN (REV) PASSENGER'S KICK PANEL LF Window Up DARK BLUE (REV) DRIVERS DOOR SWITCH LF Window Dn BROWN (REV) DRIVERS DOOR SWITCH RF Window Up WHITE (REV) DRIVER DOOR HARNESS RF Window Dn ORANGE (REV) DRIVER DOOR HARNESS Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation. Wait to start wire is at pin 16 at the ECM in a 58 pin plug, it is a blue wire negative polarity. My recommendation for a security/alarm is DEI, something like the Avital 4400/Hornet 564T. Easy to install (IMO)and very reliable. For bypassing your Passlock I recommend the GMBP by trilogix(bypasskit.com). The GMBP is by far the easiest way to bypass that system. ------------- Installer, IT support, and FFL. I need less hobbies. Posted By: turboawd Date Posted: December 01, 2007 at 9:26 AM Twelvoltz wrote: you mentioned passlock 1. did you mean passlock 2? also those systems you recommended seem pretty good. how about a system with a 1 mile range? like the viper 7900/5900? are they good? i'd like a system with a long range. thanks for the help. this is an awesome site. Posted By: mobile1 Date Posted: December 01, 2007 at 8:30 PM The GMBP will do passlock II and I believe thats what he meant. The 5900 and 7900 are great units. Both reliable and pretty straight forward. The only issue I've seen with DEI 2way remotes, are sometimes the remote stops receiving a signal from the vehicle. The features still work in the vehicle, just not 2waying. There are some loose solder joints on the circuit board of the remote that can be re-soldered and it will work again. Not a common problem but I have seen it more than once.
Posted By: Twelvoltz Date Posted: December 01, 2007 at 10:21 PM LOL, it was the letter I as in "me". It should have read "Passlock, I" missed a comma and threw everything off grammar is not my strong suite.
------------- Installer, IT support, and FFL. I need less hobbies. |
