aftermarket keyless entry
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99543
Printed Date: May 14, 2026 at 11:49 AM
Topic: aftermarket keyless entry
Posted By: charlie cornwel
Subject: aftermarket keyless entry
Date Posted: December 01, 2007 at 6:16 AM
I am getting ready to install an aftermarket keyless entry on a  2005 Ford Taurus, that has electric locks but not keyless.
I need a wiring diagram for the underdash ( SJB  ,   GEM  and   Ignition switch plug ) for a 2005 Ford Taurus  3.0 v6 a/t ,also could use some pointers if anyone has done this install
I have an Autoivox AA-925 kit  and  want to be able to lock/unlock the doors with domelight to light up with unlock, open the trunk and have it lock the doors with ignition on.
Thank you for the help
CEC
Posted By: Twelvoltz
Date Posted: December 01, 2007 at 6:42 AM
Audiovox Lists:
          #505770: 2005 FORD TAURUS 4DR SEDAN
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Battery          GREEN/ BLACK          (+)          RADIO HARNESS
     Accesory          BLACK/ PINK          (+)          RADIO HARNESS
     Ground          BLACK/ GREEN          (-)          RADIO HARNESS
     LF Speaker (+)          ORANGE / GREEN
     LF Speaker (-)          BLUE/WHITE
     RF Speaker (+)          TAN/GREEN
     RF Speaker (-)          GREEN/ ORANGE
     LR Speaker (+)          GRAY/BLUE
     LR Speaker (-)          BROWN / YELLOW
     RR Speaker (+)          BLACK/ VIOLET
     RR Speaker (-)          ORANGE / VIOLET
     Radio Security          YES
     Security
     Battery          LIGHT GREEN/ VIOLET          (+)          IGNITION SWITCH HARNESS
     Ignition 1          RED / LIGHT GREEN          (+)          IGNITION SWITCH HARNESS
     Starter 1          RED / LIGHT BLUE          (+)          IGNITION SWITCH HARNESS
     All Door Trigger          BLACK/ BLUE          (+)          DRIVER'S KICK PANEL
               YOU MUST DIODE ISOLATE ALL TRIGGERS TO MONITOR ALL DOORS. *SEE DOCUMENTS
     Domelight Super          BLACK/ BLUE          (+)          DRIVER'S KICK PANEL
     LF Latch          YELLOW/BLACK          (-)          DRIVERS DOOR BOOT
               ON SOME MODELS YOU MAY HAVE TO PULSE THIS WIRE (-) TO WAKE UP THE LOCKS. TO TEST FOR THIS: OPEN DRIVERS WINDOW AND REACH IN AFTER 3 MINUTES AND TRY AND UNLOCK DOORS WITH TRIM SWITCH. IF THEY DONT THEN U MUST USE THIS METHOD
     RF Latch          GRAY/RED          (+)          AT GEM MODULE TO LEFT OF STEERING COLUMN BEHIND DRIVERS SIDE DASH
     LR Latch          LIGHT GREEN/ YELLOW          (+)          AT GEM MODULE TO LEFT OF STEERING COLUMN BEHIND DRIVERS SIDE DASH
     RR Latch          PINK/LIGHT BLUE          (+)          AT GEM MODULE TO LEFT OF STEERING COLUMN BEHIND DRIVERS SIDE DASH
     Trunk Trigger          WHITE/ YELLOW          (-)          AT MODULE TO LEFT OF STEERING COLUMN
     Hood Trigger          TAN/LIGHT GREEN          (-)          AT VEHICLE FUSE PANEL
     Alarm Disarm          PINK/WHITE          (-)          DRIVER'S KICK PANEL
     Parking Lights          BROWN          (+)          AT VEHICLE LIGHT SWITCH
     Convenience
     Headlights-Lo          RED / YELLOW          (+)          AT VEHICLE LIGHT SWITCH
     Wipers-Lo          DARK GREEN          (+)          AT VEHICLE FUSE PANEL
     Trnk Release          VIO/YEL          (-)          AT TRUNK RELEASE SWITCH
     Remote Start
     Ignition 2          GRAY / YELLOW          (+)          IGNITION SWITCH HARNESS
     Accessory 1          GRAY / YELLOW          (+)          IGNITION SWITCH HARNESS
     Accessory 2          BLACK/ GREEN          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Type          FORD PATS® OR SECURILOCK® VEHICLE IMMOBILIZER
     Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Key Sense          BLACK/ PINK          (-)          6-WAY PLUG TO THE RIGHT OF STEERING COLUMN
     Tachometer          TAN / YELLOW          (-)          AT MODULE ON FIREWALL - PIN #48
     Speed Sense          GRAY/BLACK          (AC)          IN HARNESS ON PASSENGER SIDE OF FIREWALL UNDER HOO
     Brake Lights          RED / LIGHT GREEN          (+)          AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights          BLACK/ PINK          (+)          IN HARNESS TO TRANSMISSION
     Horn          BLUE          (-)          6-WAY PLUG TO THE RIGHT OF STEERING COLUMN
     Modules
     WIRE          LOCATION
     Please select another category
     Doorlocks/Windows
     Power Unlock          PINK/GREEN          (-)          IN HARNESS IN DRIVERS KICKPANEL
               ON SOME MODELS THE UNLOCK MAY "FALL ASLEEP". FIND THE YELLOW/BLACK LATCH WIRE IN THE DRIVERS DOOR BOOT AND PULSE WITH (-) ON UNLOCK.
     PowerLock          PINK / YELLOW          (-)          IN HARNESS IN DRIVERS KICKPANEL
     Driver Mtr Unlock          RED / ORANGE          (REV)          IN HARNESS IN DRIVERS KICKPANEL
     Driver Mtr Lock          RED / WHITE          (+)          IN HARNESS IN DRIVERS KICKPANEL
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
Date Posted: December 01, 2007 at 9:38 AM
Thank you very much!!     TWELVOLTZ
This will help me very very much
CEC
Posted By: mobile1
Date Posted: December 01, 2007 at 8:41 PM
As listed in the Audiovox tech sheet, some Fords have a GEM shutdown. The way to test for this is to have the drivers window open, lock the car by pressing the switch on the door, then shut the door. Wait 5-10 minutes and try to unlock the car by pressing the switch on the inside of the car on the door. If the locks don't do anything, you have the shutdown feature. If they do unlock, you don't have that feature.
There is a way to shut off this feature on most Fords also. Here's the process for that:
Turn the ignition on, then push unlock on the drivers door switch 3 times.
Turn the ignition off, then push unlock on the drivers door switch 3 times.
Turn the ignition on, the horn should honk at you, then hit unlock twice.
now shut off the ignition. This will disable the shutdown feature from Ford and you won't have to worry about the locks not working after a few minutes or tapping into any additional wires to make your locks work. On a couple of vehicles I've had to do this process with the driver's door open and some with it closed, so if it doesn't work on the first try, try it with the door open/closed.
Other than that TEST you wires first. The biggest mistake most people make is assuming the tech sheet is always right. Its just a guide for you. If you have any more questions let us know.
Date Posted: December 01, 2007 at 9:48 PM
Good information to know, I was not aware you could shut this feature off. Do you have a reference for where you got this information from? Is it in the owner's manual? Is there a site that you got it from? If there is could you please share, I would like to know if there are any other tricks like this for other vehicles as well.
Posted By: mobile1
Date Posted: December 01, 2007 at 10:44 PM
I used to have a buddy who worked at a ford service center. I wish I could remember the things he taught me. I know there are ways to shut off the seat belt chime and a whole bunch of other things. I can't for the life of me remember anything else though. It was a while ago.
Date Posted: December 01, 2007 at 10:50 PM
The seat belt chime is listed in the Owner's manual. Just did not know if the GEM shutdown turn off was listed or not. Ohh well, thanks for the information!
Posted By: tedmond
Date Posted: December 02, 2007 at 12:27 AM
good info mobile i guess no need to wake up BCM
Date Posted: December 03, 2007 at 7:08 PM
Thanks a lot mobile 1 , my car does have that feature and this will save me a lot of time .
CEC
