2008 buick lucerne parking lights
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99544
Printed Date: May 14, 2026 at 1:02 PM
Topic: 2008 buick lucerne parking lights
Posted By: sminc
Subject: 2008 buick lucerne parking lights
Date Posted: December 01, 2007 at 7:35 AM
I installed a remote start with keyless entry yesterday. I got all do and was checking out the system and found that the parking lights were not working. I checked all fuses and checked the wire that I used on the car to make sure that it didnt break. Everything checked out ok. I have no idea why the lights are still not working. If anyone has any info please let me know.
Posted By: techman93
Date Posted: December 01, 2007 at 7:45 AM
Parking Lights     BROWN / WHITE     (-)     AT VEHICLE LIGHT SWITCH
Is this what you hooked up to?
Tech data says BROWN at parking light bulbs (+) and I don't see any special parking light diagram for this vehicle. You may want to test the brown wire at one parking light and see if you connect up to it that it will power the rest of them as well. If not You may need to diode isolate left and right.
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
Posted By: KarTuneMan
Date Posted: December 01, 2007 at 9:42 AM
The astrochart shows a light blue/tan (NEG)- @ the bcm pass. side.
White plug between the green, and blue.
Date Posted: December 01, 2007 at 10:19 AM
Scytek shows that as well. It says pin 8 in white connector at BCM located above passenger kick panel (-) light blue/tan.
Posted By: mobile1
Date Posted: December 01, 2007 at 8:26 PM
Audivox says BROWN / White at the switch (-). Just to get another tech site in. posted_image
