please help with remote starter!
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=9956
Printed Date: March 15, 2026 at 5:17 AM
Topic: please help with remote starter!
Posted By: GUSHANAS@aol.co
Subject: please help with remote starter!
Date Posted: February 23, 2003 at 3:57 PM
Hi,
I recently baught a alarm, KeyLess Entry, and Remote Starter system LCD for my 1992 CAMARO RS.  There are 3 relays for the ignition wires, and 1 for the Kill relay. I have a picture to the wiring diagram in the link below:
https://members.aol.com/GUSHANAS/Diagram1.jpg
The 12 Pin harness which has the trunk release, keyless entry, siren, lights, etc. is hooked up and everything works fine!  BUT the 9 Pin harness which is the Remote Starter does not. If the button on the LCD Remote is pushed nothing happens not even a click out of any of the 4 relays.  I have it wired as follows:
YELLOW - Start kill relay output =kill relay yellow
 -BLUE On Kill Relay - ACC = Orange ACC. wire in ignition harness
 -GREEN 1 + 2 - between ignition wire and coil
ORANGE - Foot Brake Imput = Light blue on foot brake
BLUE - Doog Trig. Imput = White on door kick panel / door trigger
WHITE - ACC. = to BLACK Door Unlock
BLACK/ WHITE - Window Module Output = ??????? i donno where it goes?!?
PURPLE - Starter Sensing Imput = rapped around coil wire 8 times
YELLOW + BROWN + BLUE = connected to plug then plug to relays
YELLOW - Start = YELLOW
BROWN - ON1 (ignition Coil) = Pink
BROWN - ON2 = ORANGE ACC. WIRE
BLUE - ACC. = ORANGE
RED - +12V = to 1 of 2 constant red wires
pleaseeee help me out anyone!!!!!!! i am desprite and tryed everything possible!!!!!!
Thanks,
Brett
Posted By: jrilla
Date Posted: February 23, 2003 at 4:02 PM
I am not sure what brand the unit is from the diagram, but some starters require you learn the tach signal before it will even try to remote start. Some require you to initialize the unit too. Check your manual to see of there is anything that you need to do after installation is complete and before you attempt to start it for the first time.
J Rilla
Owner/Installer
