crimestopper rs 1905fm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99580
Printed Date: April 01, 2026 at 7:26 PM
Topic: crimestopper rs 1905fm
Posted By: thefranchise
Subject: crimestopper rs 1905fm
Date Posted: December 02, 2007 at 10:13 AM
I'm installing a RS 1905FM in an Infiniti I35. Ive verified all inputs to the brain twice.
Brain will not enter programming mode (5 clicks). I can enter the remote programming mode of 4 clicks though and register my remotes. The keyless entry works (although i need to change it to double pulse). Remote start even works. The unit will not remote start with the hood pin grounded but will enter remote programming mode with the hood pin not grounded (which its not supposed to).
Any ideas? ANy master reset trick out there for Crimestopper brains?
Posted By: srotap
Date Posted: February 03, 2008 at 11:41 AM
There are a number of different things people have found. Do a search on "crimestopper program" "crimestopper problem" and "crimestopper programming". There seem to be a few quirks with the crimestopper brains. My addition to the list is that on the CS-2014 DP II TW2 I just installed in a Jeep Wrangler, ignition has to be on BEFORE the hood pin is grounded for it to work. This is the opposite of the order listed in the manual.
Good luck
