| Print Page | Close Window |
07 tacoma wiring for remote startPrinted From: the12volt.comForum Name: Car Security and Convenience Forum Discription: Car Alarms, Keyless Entries, Remote Starters, Immobilizer Bypasses, Sensors, Door Locks, Window Modules, Heated Mirrors, Heated Seats, etc. URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=99637 Printed Date: April 09, 2026 at 12:15 AM Topic: 07 tacoma wiring for remote start Posted By: chuck8ch Subject: 07 tacoma wiring for remote start Date Posted: December 03, 2007 at 9:55 PM just want to double check before I snip. '06 and '07 Tacoma wiring the same. I bought a Commando RS-560 remote starter. Can I connect the wires at the steering column ignition?
------------- chuck8ch Replies: Posted By: Twelvoltz Date Posted: December 04, 2007 at 7:40 AM Audiovox lists:
#511794: 2007 TOYOTA TACOMA 2DR EXTENDED CAB Audio/Mobile Video WIRE COLOR POLARITY LOCATION Battery BLUE / YELLOW (+) RADIO HARNESS Accesory GRAY (+) RADIO HARNESS Ground BROWN (-) RADIO HARNESS Illumination GREEN (+) RADIO HARNESS LF Speaker (+) PINK LF Speaker (-) VIOLET RF Speaker (+) LIGHT GREEN RF Speaker (-) BLUE LR Speaker (+) BLACK LR Speaker (-) YELLOW RR Speaker (+) RED RR Speaker (-) WHITE Radio Security YES Security WIRE COLOR POLARITY LOCATION Battery WHITE/ RED (+) IGNITION SWITCH HARNESS Ignition 1 BLACK/ RED (+) IGNITION SWITCH HARNESS Starter 1 GREEN/ BLACK (+) IGNITION SWITCH HARNESS All Door Trigger BLUE (-) AT FUSE BOX BLACK 13 PIN PLUG PIN 9 LF Latch GREEN/ YELLOW (-) AT BECU 18 PIN PLUG PIN 7 MUST DIODE ISOLATE EACH WIRE RF Latch RED / BLACK (-) AT BECU 22 PIN PLUG PIN 8 MUST DIODE ISOLATE EACH WIRE LR Latch PINK/BLACK (-) AT BECU 18 PIN PLUG PIN 6 MUST DIODE ISOLATE EACH WIRE RR Latch PINK/BLACK (-) AT BECU 18 PIN PLUG PIN 6 MUST DIODE ISOLATE EACH WIRE Alarm Disarm DISARMS WITH UNLOCK Alarm Arm ARMS WITH LOCK Parking Lights GREEN (+) AT VEHICLE FUSE PANEL Low Crr Pk Lights GREEN (-) AT LIGHT SWITCH Convenience WIRE COLOR POLARITY LOCATION Headlights-Lo PINK (-) AT VEHICLE LIGHT SWITCH All Hazrd Lights RED / WHITE OR WHITE (-) AT SWITCH Wipers-Lo BLUE/BLACK (+) AT SWITCH Wipers-Hi BLUE RED (+) AT SWITCH Parking Brake GREEN/ YELLOW (-) AT FUSE BOX 18 PIN PLUG PIN 5 Remote Start WIRE COLOR POLARITY LOCATION Battery WHITE/ RED (+) IGNITION SWITCH HARNESS Ignition 1 BLACK/ RED (+) IGNITION SWITCH HARNESS Ignition 2 BLUE / YELLOW (+) IGNITION SWITCH HARNESS Accessory 1 WHITE/ GREEN (+) IGNITION SWITCH HARNESS Starter 1 GREEN/ BLACK (+) IGNITION SWITCH HARNESS Starter 2 BLACK/ WHITE Anti-Theft Type UNIVERSAL Anti-Theft Descript KEY SENDS AN RF SIGNAL TO THE BCM THROUGH AN ANTENNA AROUND THE IGNITION CYLINDER Key Sense GREEN/ BLACK (-) IGNITION SWITCH HARNESS PULSE WITH GROUND DURING REMOTE START WILL DISARM FACTORY ALARM Tachometer BLACK/ WHITE (AC) AT DATA LINK CONNECTOR UNDER DRIVER DASH PIN 9 Speed Sense VIOLET/WHITE (AC) AT FUSE BOX BLACK 13 PIN PLUG PIN 5 Parking Lights GREEN (+) AT VEHICLE FUSE PANEL Low Crr. Pk Lights GREEN (-) AT LIGHT SWITCH Brake Lights BLUE (+) AT FUSE BOX 11 PIN PLUG PIN 2 Reverse Lights RED / WHITE (+) DRIVER KICK Horn GREEN/ RED (-) AT FUSE BOX 18 PIN PLUG PIN 10 Modules WIRE LOCATION Module 1 THE BODY ECU IS ATTATCHED TO THE BACK OF THE FUSE BOX Doorlocks/Windows WIRE COLOR POLARITY LOCATION Power Unlock GREEN/ BLACK (-) DRIVER KICK DOUBLE PULSE PowerLock VIOLET (-) DRIVER KICK Driver Mtr Unlock BLUE/BLACK (REV) DRIVER KICK Driver Mtr Lock BLUE/RED (REV) DRIVER KICK Pas Mtr Unlock BLUE/BLACK (REV) PASSENGER KICK LF Window Up BLUE (REV) AT SWITCH IN DOOR LF Window Dn BLUE/BLACK (REV) AT SWITCH IN DOOR RF Window Up BLUE / YELLOW (REV) DRIVER KICK RF Window Dn BLACK (REV) DRIVER KICK LR Window Up GREEN / WHITE (REV) DRIVER KICK LR Window Dn GREEN RED (REV) DRIVER KICK RR Window Up GREEN/ BLACK (REV) DRIVER KICK RR Window Dn GREEN (REV) DRIVER KICK Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation. Yes you would make most of your connections at the ignition harness at the steering column. ------------- Installer, IT support, and FFL. I need less hobbies. Posted By: chuck8ch Date Posted: December 04, 2007 at 9:21 PM Thanks Twelvoltz
------------- chuck8ch |
